Old 12-02-2013, 11:18 AM   #57
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Not to jack and jump in this discussion but can you guys expand on the reason for 0w-20 and how does it affect bearings and clearance ?
Old 12-02-2013, 12:27 PM   #58
Calum
That Guy
Drives: 2013 asphalt FRS MT
I'll take a crack at it.
Viscosity is a fluid's resistance to flow. The higher the viscosity the higher the resistance. As the clearances get tighter the oil will need a lower viscosity inorder to properly flow around the bearing. And, if the clearances weren't tight enough, the oil might flow out of the bearing too quickly. 0w-20 has a significantly lower viscosity than 5w-30 or 10w-30 so it should be used with tighter clearances. By using a lower viscosity oil the motor will run a little more efficiently as the pumping losses are lower, and everything else seems to have been made to suit that lower viscosity.
The Following 3 Users Say Thank You to Calum For This Useful Post:
DAMotorsports (12-03-2013), F1point4 (12-05-2013), SmsAlSuwaidi (12-02-2013)
Old 12-02-2013, 12:51 PM   #59
OrbitalEllipses
Drives: Attitude
And let me put my hat in; you want a quality oil additive package and viscosity such that the shear strength is high. When the oil shears, it loses viscosity and no longer does the job it's supposed to do. That is basically the oil debate as it will continue for eternity.
The Following 3 Users Say Thank You to OrbitalEllipses For This Useful Post:
Calum (12-02-2013), F1point4 (12-05-2013), SmsAlSuwaidi (12-02-2013)
bearing, bearings, built, engine, forged
Catch Can Debate wootwoot Engine, Exhaust, Transmission 141 06-08-2017 01:12 PM
PAUTER ROD WITH ACL RACE BEARINGS cf6mech Engine, Exhaust, Transmission 48 09-22-2014 12:01 AM
BRZ vs FRS - The Debate TAP Auto Parts Scion FR-S / Toyota 86 GT86 General Forum 139 05-07-2013 06:26 PM
Fortune Auto V4 500s W/ Roller bearings FR-S86 Brakes, Suspension, Chassis 21 02-12-2013 03:30 PM
Forget the NA vs Turbo debate!!!! Midship Runabout Engine, Exhaust, Transmission 69 04-05-2011 05:24 PM
