Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
01-17-2016, 12:50 PM | #57 | |
Drives: None
Sent from my LG-D850 using Tapatalk |
01-17-2016, 12:51 PM | #58 | |
Drives: None
02-09-2016, 10:45 AM | #59 |
I swapped out my exhaust phaser and it seems to have resolved it. I put a spare motor of mine in recently and used the exhaust phaser from the engine that had the code above. The stock engine threw the same code... I'll check the docs in the next week or two and see where they end up.
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
03-01-2016, 10:00 PM | #60 | |
Drives: None
Mine got code cleared after I swapped out the ecu Sent from my iPad using Tapatalk |
03-22-2017, 03:17 PM | #61 | |
Drives: 2017 TOYOTA 86
They are all the same code, but for a different cam: P0016 - Crankshaft Position - Camshaft Position Correlation (Bank 1 Sensor A) = Intake, Bank 1 P0017 - Crankshaft Position - Camshaft Position Correlation (Bank 1 Sensor B) = Exhaust, Bank 1 P0018 - Crankshaft Position - Camshaft Position Correlation (Bank 2 Sensor A) Intake, Bank 2 P0019 - Crankshaft Position - Camshaft Position Correlation (Bank 2 Sensor B) Exhaust, Bank 2 The ECM can not determine the cause of the correlation error, just that the values are not matching up. It does not know if it is mechanical or electrical. |
09-23-2022, 02:33 PM | #62 |
Drives: 2013 Subrau BRZ
Hi Gentlemen,
Reviving this old thread in hopes that someone can help me out with a few questions about fixing the P0018 engine code. Some background I just bought the car used a week ago, and it has been throwing the P0018 for an unknown amount of time prior to me buying it. The previous owner mentioned they brought it to Subaru to have it diagnosed and they said it just needed a "cam sensor". I have since replaced the driver's side intake cam sensor (probably not necessary) which did nothing to fix the issue. I then swapped the intake and exhaust OCVs from left to right, and cleared the code again only to have it pop right back up next time I drove on the same side as before. From here, it was clear it was not the sensor or OCV causing the issue. Next step was the intake CAM sprocket which was just replaced at the Subaru dealer. This seems to have indeed fixed the issue as the car is now idling perfectly (it used to hunt for idle and dip down below 400RPM and almost stall) but the P0018 code remains. Even when cleared, it pops back up after only a short drive. Based on everything I've read here, it seems the ECM is the last thing that will need to be replaced as it has apparently permanently learned "bad" values that cannot be overridden. My questions: 1. When people refer to the "ECM" do they mean the main control module under the glove box in the cabin, or is it the smaller module on the passenger side of the engine in the engine bay? Both seem to be available on eBay for ~$100 and both seem to be called "ECM" interchangably. I'm not sure which I need to replace. 2. I have heard about updated ECM ROMs that can be loaded to fix this issue. Is there any point pursuing this, or is this just nonsens? Is it really true that there's no way to "reset" the ECM to default values to undo the bad values values it has learned? This seems absurd to me. I would hugely appreciate any help on this issue. I'm supposed to have a track day on the 30th and am deperately trying to get this all fixed by then Thanks! Owen |
09-23-2022, 03:52 PM | #63 | |
Drives: Crapcan
2. I am not sure about this. I believe I have seen some threads where they swapped the ECM into another car and swapped it back and it worked, but I would have to hunt that down. Be sure to follow this guide if you do swap ECM's. https://www.ft86club.com/forums/showthread.php?t=102810
09-23-2022, 11:07 PM | #64 |
Thank you so much for the quick reply!
I'll get the main ECM on order and report back... I was considering writing up a guide for this given how textbook my experience has been, but only if it all works out Fingers crossed this fixes it, and that I don't buy a used ECM on ebay with the exact same issue. |
10-07-2022, 12:49 PM | #65 |
Drives: 2018 Subaru BRZ
So P0018 light came on, replaced the cam sprockets and light is still on. Took it to a programming shop and they said timing is off, so we took it apart and double checked, and replaced timing chain while we were at it. Light still on, from what I've seen here, looks like I need a new ECU.
Fun times.... |
10-07-2022, 10:33 PM | #66 | |
Drives: Toyota 86
I solved that vvt issue after changing four cam sprockets and cam chain. Ah, reflashing was done also because I do it frequently.
/* Custom underbody panels and diffuser
Custom electric water pump and PWM controller HKS GT EL header, 17MY intake manifold */ |
10-18-2022, 11:12 PM | #67 | |
Replaced ECU and light still on.... Debating selling the car or tearing it apart again. This has been a major headache. |
05-10-2023, 05:50 PM | #68 | |
Drives: 2014 Scion FR-S
What equipment did you use to clear everything. I have done the chain, 4 cam sprockets, 4 ocv's, and the 2 sensors. Mine is with the P0018.
05-10-2023, 08:00 PM | #69 | |
Drives: Toyota 86
Hope you have good result.
05-13-2023, 02:23 PM | #70 |
chicken tonight
reported
Similar Threads | ||||
CEL P0018 | brichard0625 | Issues | Warranty | Recalls / TSB | 8 | 02-10-2016 09:44 PM |
Cams | Fabron757 | Forced Induction | 10 | 01-13-2015 06:30 PM |
HKS cams | JesseTheFlash | Engine, Exhaust, Transmission | 4 | 01-09-2015 07:42 PM |
Wtb oem cams | midnight23 | Want-To-Buy Requests | 0 | 03-19-2014 12:07 PM |
Cams | Surok | Engine, Exhaust, Transmission | 10 | 01-01-2013 08:30 PM |
