04-26-2023, 02:32 PM | #7239 | |
The Dictater
Drives: '13 Red Scion FRS
If a picture is worth a thousand words, a model is worth ten thousand pictures.
Also: "Build Thread" |
The Following User Says Thank You to Spuds For This Useful Post: | Clipdat (04-26-2023) |
04-26-2023, 02:35 PM | #7240 | |
Proud of BOXER
Drives: Subaru Boxer
Absolutely, will do!
04-26-2023, 04:36 PM | #7241 | |
Drives: Crapcan
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | Capt Spaulding (04-26-2023), Ultramaroon (04-27-2023) |
04-27-2023, 12:56 PM | #7242 |
Drives: Crapcan
My buddy at work bought a 56' two door Bel Air from my uncle. Has a small block out of a 70's truck but he got a decent deal. He called me over the other day because it wouldn't start. The aftermarket digital dash in it won't even light up until you wiggle or remove/reinstall the high tension wire from the coil to the distributor. Then we have power again. Pretty sure we have a bad contact somewhere between battery/ignition switch/aftermarket dash. He got some factory analog gauges to replace the digital unit. Still, weirdest shit I have seen in awhile
The Following User Says Thank You to NoHaveMSG For This Useful Post: | humfrz (04-27-2023) |
04-27-2023, 01:16 PM | #7243 |
Sounds like it's time to clean up the contacts/wires between the coil, distributor, battery and starter.
I'll ring up ol @Tcoat for you, he is good with those old, junked up, half breed vehicles - |
The Following User Says Thank You to humfrz For This Useful Post: | NoHaveMSG (04-27-2023) |
04-27-2023, 01:33 PM | #7244 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Whoops!
Electrical gremlins back at work this week. Went shopping a couple days ago and didn't get the trunk shut all the way again. ~ 265 mV left in the battery this morning. Going to find a neighbor to get a jump start to get a bit of charge in. The battery tender doesn't sense enough to even try starting to charge it. edit: got back from an hour drive for a bump charge. Reads 12.76 now so the tender has something to bite into. It's blinking green lights now on the tender.
"I gotta rock." -- Charley Brown Last edited by bcj; 04-28-2023 at 09:32 AM. |
04-27-2023, 05:07 PM | #7245 | |
helmholtz resonator
Drives: '15 ultramarine
The Following User Says Thank You to Sapphireho For This Useful Post: | soundman98 (04-28-2023) |
04-27-2023, 06:15 PM | #7246 |
helmholtz resonator
If I had a '56, and money to burn, I would put this under it with an LS and 6mt.
The Following 3 Users Say Thank You to Sapphireho For This Useful Post: |
04-27-2023, 07:09 PM | #7247 | |
Drives: Crapcan
He has an appointment to take it into a specialty shop on Tuesday. I'd rewire it for him proper, I just don't have time. He ordered an ignition switch, and picked up a set of factory gauges locally. We weren't able to rule out the ignition switch in the time I had to look at it. I'm pretty sure it is something to do with everything tying together at the ignition switch.
04-27-2023, 07:13 PM | #7248 |
helmholtz resonator
04-27-2023, 07:48 PM | #7249 | |
https://www.vfnfiberglass.com/5557chevy.htm
04-27-2023, 08:55 PM | #7250 |
Drives: Crapcan
We tried that, and we tried a new coil.
04-28-2023, 12:41 AM | #7251 | |
helmholtz resonator
Off to buy lottery tickets. |
04-28-2023, 12:42 AM | #7252 |
helmholtz resonator
Tags |
have you turned it off/on, i heart my boxer, i still hate you all, kiss me, maple syrup, multipass, next one is a prequel, ow my balls, special_k abandoned you, the search for more money |
Similar Threads | ||||
Random Thoughts - Part Deux [NO POLITICS] | Ultramaroon | Off-Topic Lounge [WARNING: NO POLITICS] | 84004 | 03-07-2022 11:00 AM |
OEM BRZ spark plug part number? | qqzj | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 05-26-2017 11:33 PM |
Random thoughts thread | MrVito | Off-Topic Lounge [WARNING: NO POLITICS] | 37188 | 02-25-2016 10:00 AM |
Random search on bing | sdwagonjp | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 11-19-2014 07:35 PM |
