03-08-2016, 06:43 PM | #715 |
Drives: '22 BRZ
The Following User Says Thank You to DocWalt For This Useful Post: | texasbound972 (03-08-2016) |
03-08-2016, 08:15 PM | #716 |
Drives: BRZ/FRS/STI/M3
03-08-2016, 10:34 PM | #717 |
Drives: 2014 BRZ SCCA STU endurance car
it responds to the "oh shit" handle
The Following User Says Thank You to Gear_One_Performance For This Useful Post: | sato (07-09-2016) |
04-25-2017, 01:37 PM | #718 |
Drives: Hydra EMS Powered FRS Raven Black
Updates after 1.5 years of racing
I know it's been forever since I've updated anything or even been on the forums. Honestly we have just been busy with engine building, client builds, and new projects. We also had been racing with the same FA20 successfully for over 1.5 years. Great photo by @JonAthanboppenheim
Our number one goal for our engine package was to get reliable oil pressure under racing conditions for higher power and also for our 9k rpm head package. As you can see these bearing could just go right back into the motor! What nobody knew was that were were also testing WRX DIT parts in our engine as a means to further develop that platform without having to build another WRX race car. With the lower compression pistons and downright beefy ringlands we decided it was worth seeing how these engines held up. Now these do not drop into the BRZ motor so don't get any bright ideas but we broke multiple track records with this motor over the last 1.5 years. If you've never seen this FRS Time Attack car in action, it's absolutely mental! Here's a record run and a win at Gridlife Atlanta. Even in 100 degree weather I was able to match my best ever lap there of 1:30.3 [ame="https://www.youtube.com/watch?v=2gr9ma_vFCw"]Another record lap at Gridlife Road Atlanta in the Time Attack FRS - YouTube[/ame] That wasn't good enough for the racer in me and I wanted a sub 1:29 as I knew the car and me had it in us. As we all know that transmission is on the brink at 400 whp and so we've always raced it there and even detuned it more in 4th gear. My car has made over 500 whp on race fuel however and I wanted to risk it but even on E70 my fuel system was barely adequate for 400 whp. Given I would only turn it up in 5th and 6th I decided to risk a couple more psi even though I knew it would run lean. As I approached the last turn it let go and I coasted across the line with a 1:30. So close and so not worth it. Hahahaha! The carnage of what's left of the OEM cast piston. Even with such massive destruction (it let go at 120 mph) you can still see how effective the oiling and engine mods were in our car. Now this is the major downside to a cast piston! Even though this piston handled over 500 whp on the street, and 400 whp racing for 1.5 year, when things go wrong the piston shatters in spectacular fashion. A forged piston would never do this so it's it's well worth the upgrade cost even though these FA pistons are a huge improvement over the EJ pistons. Thanks, Phil Grabow Last edited by Element Tuning; 05-03-2017 at 06:10 PM. |
The Following 14 Users Say Thank You to Element Tuning For This Useful Post: | AJPG (04-25-2017), BatStig (04-25-2017), DarkSunrise (04-25-2017), DustinS (04-25-2017), GsxrMe (04-25-2017), johan (04-25-2017), Jonsey (04-27-2017), Kris86 (04-25-2017), Lonewolf (04-25-2017), new2subaru (04-25-2017), RavioliG (09-01-2017), sato (04-25-2017), skylinekin (04-25-2017), SoCalArgento (04-25-2017) |
04-25-2017, 07:38 PM | #719 |
Drives: Late 2014 Subaru BRZ
Are those sexy king bearings I see?
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe |
04-27-2017, 02:26 PM | #720 |
04-27-2017, 02:33 PM | #721 |
Wes
How much labour are you looking at if you want to replace your pistons for forged items? Just curious how long it takes
04-27-2017, 07:38 PM | #722 |
The Following User Says Thank You to Element Tuning For This Useful Post: | StraightOuttaCanadaEh (04-27-2017) |
05-01-2017, 01:19 AM | #723 |
Drives: 2005 STI Race Car- 08 Spec B DD
Congrats on keeping it in one piece for 1.5 years without a dry sump. Impressive!
05-01-2017, 06:36 PM | #724 |
Thanks! Our motor build gets the oil pressure up but I'm sure the Accumulator kit has helped with cornering Gs as we've seen over 2G with our Time Attack FRS. It's cheap insurance for sure!!!
The Following User Says Thank You to Element Tuning For This Useful Post: | RavioliG (09-01-2017) |
05-04-2017, 08:25 AM | #725 | |
Drives: GT86 Harrop S/C
I was just wondering about the rods you used. I was aiming to keep the stock pistons as a way of saving money if I decide to build my engine, but was told I'd struggle to get aftermarket rods that would fit. Did you have to machine the rods to get them to fit the pistons? Sorry if the answer to this is somewhere in the last 50 pages! |
05-07-2017, 02:49 PM | #726 | |
While I made it work, it was mostly for us to test the DIT parts without buying a WRX. I also have infinite control over the DI with the Hydra EMS and I'm not sure you could get optimal results from the OEM ecu in that regard. Forged rods and pistons (for boosted applications) are the only way to go if you have opened up the motor. Don't get me wrong those pistons are strong and honestly would have never failed had I not run that motor super lean. |
The Following User Says Thank You to Element Tuning For This Useful Post: | TachyonBomb (06-05-2017) |
09-01-2017, 09:25 PM | #727 |
Poor Adult Male
Drives: 2013 Subaru BRZ
Ok Element you win take my money
The Following User Says Thank You to RavioliG For This Useful Post: | sato (09-02-2017) |
09-05-2017, 04:18 PM | #728 |
Similar Threads | ||||
FA20 Engine component photos | Crawford | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 89 | 02-22-2016 02:31 AM |
FA20 Engine component photos | Crawford | Engine, Exhaust, Transmission | 46 | 01-26-2015 05:19 AM |
Engine Hardware, Gaskets, & Bearings Oh My; All on sale at FR Sport. | FRSport.com | Engine, Exhaust, Bolt-Ons | 0 | 01-10-2014 12:33 PM |
FA20 Le Mans Race Engine | SilverSkyline210 | Engine, Exhaust, Transmission | 11 | 11-17-2013 11:24 PM |
