01-19-2015, 04:28 PM | #743 |
USMC
Drives: 2013 FR-S 6-MT Raven
02-26-2015, 11:17 AM | #744 |
Drives: Toyota GT 86
anyone know what kind of material is used in the gasket?
The shop that was doing the installation lost 1 of them, and I just want to be sure they buy the right material to replace the lost O-Ring. |
02-26-2015, 11:28 AM | #745 | |
Drives: 2015 BRZ Series.Blue
02-27-2015, 11:51 AM | #746 |
USMC
03-19-2015, 12:01 PM | #747 |
So after a long time I got a new O-ring, and I decided to install the powerblocks on my own. It really is a pain in the as_.
I had to unplug a few things, but when I restarted the car I had a P0108 error. "Manifold Absolute Pressure/Barometric Pressure Circuit High Input" I cleared the error but it popped up again. I checked all my connections, and everything looked fine. But just wanted to ask, where is the MAP sensor located to doublecheck it? |
03-21-2015, 04:00 PM | #748 |
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
So is anyone using these with one of the supercharger set ups?
04-11-2015, 02:39 PM | #750 |
Drives: 92 Prelude
04-11-2015, 07:46 PM | #751 |
USMC
This is with the power blocks.
04-16-2015, 11:47 AM | #753 |
Drives: 2013 Subaru BRZ
Did my install on these yesterday with a buddy ( highly recommend a second set of hands when doing this ) the total install went extremely smooth and only took about an hour and a half the most. And I gotta say the car feels amazing. You definitely notice the difference these make and the throttle response is 100 times better. I'm extremely pleased with these. Just need to give the car a bit more time to learn that they're in there but all in all I love the way the car drive even more.
The Following User Says Thank You to Ripp91 For This Useful Post: | Jmonty (04-18-2015) |
04-30-2015, 08:35 AM | #754 |
Drives: 2014 FRS
I put mine in this last weekend. Install went really smooth until it came time to bolt down the brake vacuum line. If you just bolt it down it makes the line really tight, So we took a piece of metal pipe the same inside diameter as the hole and cut it to 1.5 in length then used one of the factory intake bolts and the line has the same play as it did from the factory. I think Crawford should start putting one of these in the kits. By the way, the car runs great. Bill
06-06-2015, 12:59 PM | #755 |
Drives: Pearl White BRZ
Can someone explain to me why it doesn't benefit FI? it'd be doing the same thing it is right now, would it not? don't troll me. this is a 100% serious question. thanks.
07-24-2015, 09:38 AM | #756 |
Drives: 2013 BRZ DMG manual Limited
I have a set as well, but never installed them because I am running the Vortech Supercharger kit. I wish Crawford would chime in and verify that they are only good for N/A cars.
Tags |
billet, crawford, magic blocks |
Similar Threads | ||||
Crawford Performance Turbo BRZ! Balance Meets Power - Ignition Episode 71 | ZetaVI | BRZ Photos, Videos, Wallpapers, Gallery Forum | 22 | 04-01-2014 05:19 PM |
short blocks? | 350matt | Engine, Exhaust, Transmission | 4 | 11-04-2013 08:37 PM |
Billet Oil Catch Can #BC-175 by Billet Custom | Tim_Asphalt_FRS | Engine, Exhaust, Transmission | 48 | 10-27-2013 02:29 PM |
***Blitz Advance Power Air Cleaner and SUS Power Core Intakes*** | FT-86 SpeedFactory | Engine, Exhaust, Transmission | 1 | 10-07-2013 09:40 PM |
