10-07-2016, 09:48 PM | #757 |
Drives: FRS-Raven-MT
Neither really bounce around. At idle usually ltft will be 3.90 and stft will be like .78. At 2500 ltft will be a constant number, one that I listed before, but stft will bounce around a bit, usually the same numbers though. Under acceleration stft will go down to 0 and ltft will be some constant number. I should note I've been trying to diagnose a p219a code and misfires. I'll post up a log in a little bit, it's kind of hard to explain what's going on.
*** Here is my log http://datazap.me/u/trurace/log-1475...-7-10-11-12-13 I'm looking at my older logs and they don't seem much different from this one... Not really sure how to proceed at this point about this P219a code. Checked for intake and exhaust leaks. Tried cleaning the MAF. I was kind of hoping it would be a bad sensor at this point, but based on my previous logs the ltft and stft behavior seem normal I suppose. I'm stumped, maybe a bad batch of fuel? Can't say that I've noticed any change in drive ability. Last edited by TruRace; 10-07-2016 at 10:58 PM. |
10-09-2016, 11:55 AM | #758 |
Huge E85 fan!
Drives: 2016 Scion FRS
I gutted my cats and flashed a stage 2 tune the Tuesday before last. I noticed the increase in power right away, of course. But what surprises me is that for the past few days the power has really come on even more. It's weird because usually you get used to the power and the tune seems to lose power on the butt dyno. It has to be the ECU making adjustments and getting the fuel trims right? I guess?
The Following User Says Thank You to guybo For This Useful Post: | OrangeGuitar (10-09-2016) |
10-11-2016, 08:20 PM | #759 |
This Guy
Drives: 2015 Halo FR-S M/T
Can anyone shine light on why I am getting my lean alert when going WOT in 3rd gear? Here is the log.
http://datazap.me/u/thisguyrett/10-1...t?log=0&data=1 Also, I dont know what I am doing. I am on the stage 1 91 tune and set alerts mentioned in first post. Almost anytime I am using the real time data logging, i can some kind of alert. Below are the alerts. " Alert A (over temperature) Coolant Temp > 207 F Oil Temp > 250 F Select OR at bottom of screen Alert B ( knock alert & Fuel Trim alert) For E85 suggest -1 for Petrol may -2 FLKC < -1 Knock Correction < -1 IAM < 0.9 LTFT > +10 LTFT < -10 Select OR at bottom of screen I set the fuel trim alert as Im on E85 and it will alert me to excessive fuel trims due ethanol content changes or someone accidentally filling up with petrol, it will also alert you of exhaust or intake leaks. Alert C running lean alert you might have to tweak AFR for petrol/E85 try 13 for E85 12.5 Petrol RPM > 5000 Engine Load > 1 AFR > 13 Select AND at bottom of screen" Thanks in advance guys. |
10-11-2016, 08:31 PM | #760 | |
just move up the parameters slightly like 5100, load 1.05 afr 13.1 and you should be good |
10-11-2016, 09:12 PM | #761 | |
This Guy
Change the parameters on the alerts in oft or change the parameters via romraider? Thanks bud! Also, I get Knock correction alert in high gear, low rpms when speeding up, is that normal? |
10-11-2016, 09:24 PM | #762 | |
yep you will often get a bit of knock low rpm high gear with big throttle input |
10-13-2016, 07:05 PM | #763 | |
This Guy
http://datazap.me/u/thisguyrett/flkc-alert?log=0&data=1 |
10-13-2016, 09:10 PM | #764 | |
Yes the alert is going off as you have FLKC knock over -1 correction and your IAM is only 0.79 91 fuel does tend to get some knock it looks a little on the lean side as well for OFT tune is you intake stock ? exhaust headers ? which tune are you running assume 91 oft tune next time log Ignition Advance and Commanded AFR instead of lateral G and wideband AFR its not super bad but probably needs some tweaking |
10-13-2016, 09:12 PM | #765 | |
This Guy
Sent from my SM-N920V using Tapatalk |
10-13-2016, 09:16 PM | #766 | |
Hmmm ok, that should not effect afr, just seems a little lean to me, 12.2 on petrol usually ts arround 11.8 high rpm/load the only difference between 93 and 91 tune is 91 oft tune has about 1.5 degrees less advance over 5000. running 93 fuel is always going to be better if you can get it. unless you mod the tune your always going to get some knock on 91 even with 91 tune. Its less than stock tune but still going to be there. |
10-13-2016, 09:20 PM | #767 | |
This Guy
10-13-2016, 09:22 PM | #768 |
make sure you get 93 fuel in tank first else knock will be way worse :-)
10-13-2016, 09:26 PM | #769 |
This Guy
10-13-2016, 09:52 PM | #770 | |
here is current log oft tune should be running arround 11.8 higher rpm http://datazap.me/u/thisguyrett/flkc...8-9-10&solo=10 |
The Following User Says Thank You to steve99 For This Useful Post: | Teseo (10-15-2016) |
Similar Threads | ||||
WTB: Open Flash Tablet | TOZER | Canada Classifieds | 3 | 07-05-2015 07:13 PM |
Open Flash Header & Open Flash Tablet | Calavera | Engine, Exhaust, Bolt-Ons | 9 | 05-11-2015 08:27 PM |
FS: open flash headers / open flash tablet - SOLD | alanhung85 | Canada Classifieds | 12 | 02-10-2015 02:08 PM |
FS: Open Flash Tablet (OFT) | mex2309 | Engine, Exhaust, Bolt-Ons | 1 | 10-29-2014 02:49 PM |
Open flash tablet. | cooldandani | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 02-22-2014 07:14 PM |
