02-01-2023, 05:10 PM | #71 |
The Dictater
Drives: '13 Red Scion FRS
Yeah, that's part of the question. I don't think I'm going to go FI. If I move somewhere where e85 is an option (or it comes to me), I might go FF. All things being the same, if I want more power in the distant future I would probably be looking at a swap of some sort (coughFA24cough), which who knows what that looks like.
If a picture is worth a thousand words, a model is worth ten thousand pictures.
Also: "Build Thread" |
The Following User Says Thank You to Spuds For This Useful Post: | NoHaveMSG (02-01-2023) |
02-01-2023, 06:52 PM | #72 | |
Drives: Crapcan
The Following User Says Thank You to NoHaveMSG For This Useful Post: | Spuds (02-01-2023) |
02-02-2023, 12:41 AM | #73 | ||
Instagram: @spike.brz
02-02-2023, 09:53 AM | #74 | |
Drives: Crapcan
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | Spuds (02-05-2023), villainous_frx (02-02-2023) |
02-05-2023, 10:49 PM | #75 | |
The Dictater
Also got the driveshaft back on. Yes this was AFTER I filled the transmission (). Oil did not leak out the back thankfully. And fixed my airbox. This is actually held in place mote firmly than it was originally, all for the cost of two holes and a zip tie. Highly recommend this mod.
The Following 3 Users Say Thank You to Spuds For This Useful Post: |
02-05-2023, 10:54 PM | #76 |
chicken tonight
legit
02-06-2023, 10:04 PM | #77 |
The Dictater
Exhaust is hung/supported, but I am having second thoughts about these top locks. They are the elliptical kind and I tested one on a bolt and the nut was getting hot just trying to run it up the bolt. Feels a lot like cross threading and I'm a bit concerned about using them on studs in the head that would be real hard for me to fix.
Thinking of just getting new stock bolts from Subaru.
The Following User Says Thank You to Spuds For This Useful Post: | Clipdat (02-07-2023) |
02-07-2023, 12:50 AM | #78 | |
Proud of BOXER
Drives: Subaru Boxer
You definitely don't want hot nuts. At least with the OEM option you know they are the right hardware for the job/task.
The Following 2 Users Say Thank You to Clipdat For This Useful Post: | Racecomp Engineering (02-08-2023), Spuds (02-07-2023) |
02-13-2023, 05:51 PM | #79 | |
Drives: Crapcan
The Following User Says Thank You to NoHaveMSG For This Useful Post: | Spuds (02-13-2023) |
02-13-2023, 06:34 PM | #80 | |
The Dictater
Anyway, nuts and a few other not-necessary-but-nice-to-have parts are already on order so I'll try those. If it becomes a problem... well I'll threaten it first lol
The Following User Says Thank You to Spuds For This Useful Post: | Ultramaroon (02-14-2023) |
02-15-2023, 10:27 PM | #81 |
The Dictater
Suspension Install - Part 1: Nuts
So last weekend I thought I would get started on the suspension install. I'm going to go into some detail on this part. Started with the Tarmac 2s from Racecomp Engineering (who I can't seem to Mention here). Still working on getting those on the car next weekend I think lol.
Why jump straight to T2s over other options you ask? Well the first step was to realize I have no idea what I'm doing, which leads to needing to find out who knows what they are doing. It seems to me like RCE knows what they are doing so I simplified my decisions by just saying I'm getting something from them lol. As for which product, I bounced back and forth between Yellows+Dampers, SS1s, and T2s for like a month. Picked T2s in the end because I wanted the double adjustability to figure out this whole damping thing eventually. Might have gone SS2s had those been out at the time, but hey, now I have something that I probably won't grow out of for the next 9 years lol. These shipped with basic KW instructions, but I'd seen and heard mention that RCE had put together some more detailed instructions which Andrew sent over. The RCE ones are indeed better. I also got Vorshlag camber plates up front and a new set of OEM top mounts for the rear. It really came down to Raceseng or Vorshlag because those are the only plates that add both camber and caster, and also have bearing below the spherical to reduce wear. I picked Vorshlag because RCE sells a set with the correct perch so I don't have to figure that part out because again, I don't know what I'm doing. Pic also includes LCAs because . First step was to integrate the coilover-top mount assemblies. Instructions say to use a strap wrench to hold the shaft, and torque the top nut to 26ftlb. Seems easy right? I didn't have a proper strap wrench so I removed the hooks off a rubber tie down strap and tried it. I was able to get the top nut to about 15-20 ftlb using this method while cramping up my hand holding it tight. The problems are that the twisted strap by itself doesn't provide much leverage, and I couldn't make it hold tight enough to prevent it from slipping. So, after some back and forth with Andrew I went and got an actual strap wrench. Aaaand this was actually worse at holding the shaft. Maybe what I really needed was a good strap wrench, not a cheap one from the auto parts store? This one would just pill up and smear the shaft, if I got it anywhere near tight enough. Tried to get either my original strap or the strap wrench to hold 26ftlb for a few hours to no avail. What I wound up doing on the fronts (after some more discussion with Andrew) was to use my torque wrench in reverse on the top 9mm outer hex profile and use a box wrench to tighten the nut. I was able to tighten it to 20ftlb on both sides. I could have gone to 26ftlb, but 20 seems plenty tight given I'm using a 9mm socket to hold the shaft. The rears were easy by comparison. Just had to use a clamp to hold the top mount in place on the workbench and tighten one nut at a time to 15ftlb. The shaft didn't actually rotate, friction against the top mount seemed to be enough to hold it. So that was an interesting day lol.
Also: "Build Thread" Last edited by Spuds; 02-15-2023 at 11:39 PM. |
The Following User Says Thank You to Spuds For This Useful Post: | Racecomp Engineering (02-16-2023) |
02-15-2023, 10:44 PM | #82 |
The Dictater
Suspension - Part 2: Endlinks Suck
Next up, I figured I'd get the OEM struts out. First step is remove the brake line bracket and speed sensor clips. Brake line bracket was straightforward. The speed sensor cable is held to the strut by 2 clips. I was able to remove one clip entirely from the strut, the other I just removed the wire from the clip which is much easier (press the clip with a screwdriver), and I'll get the clip off once the strut is out. Apparently some of these clips are hard to source. I also unclipped the sensor cable from the wheel well in case I need a bit more slack/space.
Then it was the end links... Nine year old endlinks with rusted to shit threads are a PITA. Needless to say the end links are destroyed and I need new ones. The real question is whether I want adjustable endlinks, OEM, or go middle ground with some Perrin endlinks to match the sway bar... Need to make a decision this week or I'll be really behind schedule.
Also: "Build Thread" Last edited by Spuds; 02-15-2023 at 11:04 PM. |
02-15-2023, 11:32 PM | #83 |
The Dictater
Oh, also I really hope that the "R" coilover gets mounted to the "RH" top mount and "L" to the "LH" top mount, or I'm going to have to do it again...
02-15-2023, 11:48 PM | #84 | |
Sent from my Pixel 6 using Tapatalk
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post: | Spuds (02-15-2023) |
Similar Threads | ||||
2018 Camaro SS 1LE vs Spuds' FRS | Spuds | FR-S / BRZ vs.... | 13 | 06-16-2019 10:11 PM |
FRS from Vroom - RISKY? | Cosa | Scion FR-S / Toyota 86 GT86 General Forum | 14 | 10-21-2018 09:27 PM |
So my key FOB was put in the washing machine.... | Kayzer Soze | BRZ First-Gen (2012+) -- General Topics | 11 | 06-07-2013 11:43 AM |
Vroom! - This week's blipshift shirt | blipshift | Miscellaneous | 1 | 11-13-2012 10:29 PM |
