02-15-2023, 11:51 PM | #85 | |
Sent from my Pixel 6 using Tapatalk
2013 Series 10 FRS #553
The Following 3 Users Say Thank You to jflogerzi For This Useful Post: |
02-16-2023, 04:56 PM | #87 |
Drives: Crapcan
The Perrin endlinks also suck. They stick out too far from the mounting tab and hit the inner fender at lock. I ordered whitelines but could not adjust them down far enough that the end of the sway bar would hit the lower control arm. So I set my car on the ground with no endlinks, measured eye to eye as best I could with the swaybar about where I thought it needed to be, and ordered a set in the correct range from whiteline that are shorter than the recommended if you put in an FRS as the model. I know these are not popular from previous quality issues but they have been okay so far for me.
What I also found for strap wrenches that works better on smaller shafts, is to undo the loop, wrap it a few times around the shaft(it will be offset because of this) then run it back through the loop and hold tight as normal. Gives it a little more to grab. This is why I went to just using the impact gun, less hassle. The wrench I have looks like this one but different brand for reference, but is much smaller. https://www.homedepot.com/p/Husky-8-...APWR/300117125
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | Spuds (02-16-2023), Ultramaroon (02-16-2023) |
02-16-2023, 05:12 PM | #88 |
The Dictater
Drives: '13 Red Scion FRS
Anything I should know about combining T2s and the various end links on offer? Is the mounting point the same height as stock, any known combinations that don't work for whatever reason, etc?
If a picture is worth a thousand words, a model is worth ten thousand pictures.
Also: "Build Thread" |
02-16-2023, 05:19 PM | #89 |
chicken tonight
I feel a twinge of guilt whenever I bust out the air tools. I have an assortment but can't remember the last time I used one.
There's another French -ment suffix! An assortment is a thing. A fitment is a fucking thing, goddammit!
02-16-2023, 05:37 PM | #90 |
I am 2 using the Whiteline end-links without issues. I do have the Front Whiteline swaybar as well. I run it on the stiff settings
https://www.ftspeed.com/part/bsf45z-...7#.Y-6wVHbMKUk
The Following User Says Thank You to jflogerzi For This Useful Post: | Spuds (02-16-2023) |
02-16-2023, 06:10 PM | #91 | |
Drives: Crapcan
https://www.ft86club.com/forums/show....php?p=3270440
The Following User Says Thank You to NoHaveMSG For This Useful Post: | Spuds (02-16-2023) |
02-16-2023, 06:38 PM | #92 | |
The Dictater
02-16-2023, 08:16 PM | #93 |
Drives: Crapcan
From that older thread, looks like a lot of us where using the KLC180-210.
02-16-2023, 10:13 PM | #94 | |
The Dictater
Looking on whiteline.au I was able to get the lengths for reference. KLC179: 225mm-250mm KLC180-215: 210mm-235mm
02-17-2023, 11:14 AM | #95 |
Drives: Crapcan
I think I started on the 179's but went to the 180-215. Looking back I was almost as short as the 179's would go.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | Racecomp Engineering (02-17-2023), Spuds (02-17-2023) |
02-17-2023, 05:50 PM | #96 | |
The Dictater
https://whitelineperformance.com/pro...-sway-bar-link
02-17-2023, 06:10 PM | #97 | |
Drives: Crapcan
The Following User Says Thank You to NoHaveMSG For This Useful Post: | Spuds (02-17-2023) |
02-17-2023, 06:21 PM | #98 | |
The Dictater
I didn't actually measure the ride heights before lifting the car either so we're going to see what happens when I stick the perches in the center of the recommended range and adjust from there.
Similar Threads | ||||
2018 Camaro SS 1LE vs Spuds' FRS | Spuds | FR-S / BRZ vs.... | 13 | 06-16-2019 10:11 PM |
FRS from Vroom - RISKY? | Cosa | Scion FR-S / Toyota 86 GT86 General Forum | 14 | 10-21-2018 09:27 PM |
So my key FOB was put in the washing machine.... | Kayzer Soze | BRZ First-Gen (2012+) -- General Topics | 11 | 06-07-2013 11:43 AM |
Vroom! - This week's blipshift shirt | blipshift | Miscellaneous | 1 | 11-13-2012 10:29 PM |
