Old 10-07-2023, 04:12 PM   #967
otter
Drives: 22 BRZ
Tire gauges are a bit like a dyno to me - consistency matters more than accuracy. That said, the Joe's Racing gauges that many people use (incl myself) aren't terribly accurate over time. Just threw one away that decided to start reading significantly low - I always have two gauges so I can compare, one for the garage and one in the autox box. The new one I bought reads differently than the spare that I didn't throw away so not totally sure which one is correct. I might switch to Longacre.
otter is offline   Reply With Quote
The Following User Says Thank You to otter For This Useful Post:
DocWalt (10-07-2023)
Old 04-11-2024, 07:36 PM   #968
Open Loop
2013 FR-S Whiteout / SSC
DS Build of 2023 GR86
Hi everyone,
I am planning on building my GR86 up for DS. I have the crash bolts. I purchased Koni yellows. I have 7mm spacers and I'm prepared to buy other ones if needed to get the permissible offset with the wheels I will be getting (likely RPF1). I am leaning toward the narrower Karcepts front bar.
I am interested in the best way to get the shims/sleeves needed for the Koni strut bolt holes. Should I reach out to Koni?
Also, more importantly, what do I need in the way of top hats for the rears?
Is there a conventional wisdom at this point as to what bump stops to use for Konis?
Thanks in advance.
Open Loop is offline   Reply With Quote
Old 04-13-2024, 01:20 PM   #969
strat61caster
strat61caster's Avatar
Yes contact koni direct for the legal centering washers. Shouldn’t be anything wrong with oe top hats (not that you can legally do anything about it anyway) other than maybe drilling out the rear, I can’t remember if that’s necessary on the koni, but that’s dead easy to do. The rest sounds like a reasonable starting point to someone who has only bench raced street class lol.
ineedyourdiddly
Open Loop (04-17-2024)
Old 05-02-2024, 07:06 PM   #970
dave99rt
Drives: '22 BRZ
Originally Posted by Open Loop View Post
Hi everyone,
Thanks in advance.
OEM crash bolts, spacers to arrive at 41mm total offset up front (7mm spacer if you select the 17x7.5 RPF1), Konis with centering washers, stiffer bump stops, and the Karcepts 0.804 bar. Set the bar to 2/2 or 2/3 depending on surface type and temps. Definitely run 2/2 if it's concrete and warm weather. I'd run the small bar at 2/3 or 3/3 if stock shocks and bump stops.
Bridgestone RE71RS in 245/45/17, 235/45/17, 245/40/17, or 255/40/17. Any other size is wrong.
Email Koni for the center washers: info@koni-na.com
Bump stops: Quite a a few of us run the red up front and the blue in the rear. Some run stock front stops. Trim new ones to at least ~59mm front and ~57mm rear to not exceed OEM length. You can go shorter if you want. General consensus to is to leave rears at max height. Trimming fronts down might help, but can increase the chances of the tire rubbing the fender liners. This is more common if you're running the taller 45 series tires.
https://www.resuspension.com/bump-stops/penske.html
2022 BRZ
2020 F-150
dave99rt is offline   Reply With Quote
Old 05-13-2024, 04:53 PM   #971
mr.whiskers
Drives: '22 BRZ
Originally Posted by cmiovino View Post
Thanks for subscribing!
I'll agree with you on that. I kept the stock Primacies on the stock wheels for the first year I had the car and ran them at longer distance events just for seat time. They were pretty bad, even for an enjoyment standpoint.
They're not bad for street use, even if you're moderately hooning around, but at autocross you don't even feel like you're using the 50% of the rest of the car.
Just thought I'd give an update on my first autocross event on RE-71s. In short all i can say is WOW
After Premacies its scary how much grip they provide. I had my first runs after lunch break and also had my coworker with me as a passenger (he got 0 experience with any performance driving, nor as a driver or as a passenger). The noises he was making during our run.. he said he was going to be sick. And I gotta admit even I felt my lunch moving around in my stomach with so much Gs generated in the turns.
In terms of results I am still way off from the top guys in our club but that is kind of expected. I gotta focus on conquering my fear and really pushing the car now. It feels like it can do much more. But overall they were everything I expected and more
mr.whiskers is offline   Reply With Quote
The Following User Says Thank You to mr.whiskers For This Useful Post:
strat61caster (05-13-2024)
SCCA Solo Street Modified (SM) Discussion whataboutbob Tracking / Autocross / HPDE / Drifting 61 07-27-2020 10:03 AM
SCCA Solo C Street Discussion Kido1986 Tracking / Autocross / HPDE / Drifting 4833 07-08-2020 03:52 PM
Gen3MR2's C Street (SCCA SOLO) Progress Gen3MR2 Tracking / Autocross / HPDE / Drifting 0 02-12-2016 01:02 PM
2014 SCCA Solo Nationals/Pro Solo Finale thread edj Tracking / Autocross / HPDE / Drifting 206 09-19-2014 11:34 AM
Henry's C Street (SCCA Solo) progression Kido1986 Tracking / Autocross / HPDE / Drifting 74 05-04-2014 08:20 PM
