Old 05-01-2023, 02:53 AM   #99
Pointmutation
Pointmutation's Avatar
Drives: 2016 ZC6
Originally Posted by muskasim View Post
I struggle to get the 14mm flanged bolt out as well. I found that loosening the brake pedal support assembly makes the 14mm flanged bolt out and back in pretty easy.
Remove the red bolts and just loosen the green nuts as below picture.
Quick note, the above didn't work for me. Mine was all connected to the clutch pedal assembly or whatever it's called. Is this an LHD vs RHD difference or just a manual vs auto difference, not sure as I only have experience with my own vehicle (2016 BRZ, manual, LHD).
Finally fixed and replaced the dampener and lo and behold, no more rattling!! The green part was destroyed to bits. That damn bolt though, I had to just wiggle the EPS unit and boom, the bolt came out easily. Of course I had already fought with the bolt for an hour wiggling the steering wheel (instead of the EPS unit itself) and playing with the brake pedal assembly. Finally realized what if I stick my hand up there and grab the unit itself and bam, it rotated and the bolt popped out. FML. Rattling gone!!
Another tip, wear work gloves. There are some sharp edges down there that I got sliced on.
Pointmutation is offline   Reply With Quote
The Following 2 Users Say Thank You to Pointmutation For This Useful Post:
bcj (05-01-2023), ermax (05-03-2023)
Old 05-06-2023, 11:33 AM   #100
Rican_D
Rican_D's Avatar
Drives: Asphalt FR-S
This thing was thrashed. Was fortunate, mechanic helped me out with this. Did it without removing the gauge cluster.
Sent from my Pixel 6 Pro using Tapatalk
Rican_D is offline   Reply With Quote
The Following User Says Thank You to Rican_D For This Useful Post:
MJones_RB (05-10-2023)
Old 06-03-2023, 11:05 PM   #101
aceangel
aceangel's Avatar
Drives: 13 BRZ WRB LTD 6AT
Hi all, I did this today, and the rattling is gone but my steering wheel is misaligned a few degrees to the left. Can I remove the 14mm nuts, pull the steering wheel out, and recenter it again? I saw another video where a mechanic uses a computer to reprogram it to center, ugh.
aceangel is offline   Reply With Quote
Old 06-04-2023, 02:51 PM   #102
aceangel
aceangel's Avatar
I fixed it. I only had to remove the trim to access the two front 14mm bolts. I pulled the steering wheel out and releveled it. I was using the factory marking as a guide, but it was incorrect. Luckily, the steering wheel only goes in a few certain ways, so it was easy to put it back in its normal position.
The Following User Says Thank You to aceangel For This Useful Post:
DocWalt (06-14-2023)
Old 07-06-2023, 09:03 PM   #103
Here2rock
Drives: 86 GTS
How many hours of labour is involved if getting it done through a Toyota Dealership? The repairs looks a bit complex to be honest.
Here2rock is offline   Reply With Quote
Old 07-06-2023, 09:04 PM   #104
Here2rock
Drives: 86 GTS
How? What was the total cost for the job?
Old 07-06-2023, 09:04 PM   #105
Rican_D
Rican_D's Avatar
He helped me, didn't charge me
Old 07-06-2023, 09:07 PM   #106
Here2rock
Drives: 86 GTS
Are you able to give more details as to how he did it? How many hours were involved? Removing trims etc, seem very complex.
Old 07-10-2023, 08:50 PM   #107
Here2rock
Drives: 86 GTS
Any guide on how to do without removing the cluster?
Old 07-10-2023, 08:51 PM   #108
Rican_D
Rican_D's Avatar
Honestly I don't remember, but it's possible
Is building a motor necessary for FI on this motor? Irace86.2.0 Forced Induction 44 02-27-2018 01:19 PM
Shifter Rattle and Replacement boredom.is.me Issues | Warranty | Recalls / TSB 19 04-27-2015 04:29 PM
Seized motor!! What STX mods should I do while I have the motor out?? BlaineWasHere Tracking / Autocross / HPDE / Drifting 27 12-11-2014 02:39 PM
Silicone coupler or similar that is 4" I.D., and 1 inch Thick... (SOLVED) Sportsguy83 Engine, Exhaust, Transmission 11 06-18-2014 11:29 PM
