Old 09-08-2023, 11:18 AM   #99
RedReplicant
Drives: None
Ahh, alright, fair enough
Good call on the good sensors, totally worth it. Just shoot me a PM when you decide you want to program it, all you need is a working INPA / NCSExpert setup and I can walk you through it. I wrote instructions on MiataTurbo a couple of years ago but it still isn't the easiest thing to follow without pictures.
RedReplicant is offline   Reply With Quote
The Following 2 Users Say Thank You to RedReplicant For This Useful Post:
doward (09-08-2023), gt5759 (09-11-2023)
Old 09-11-2023, 11:01 AM   #100
gt5759
Drives: 2017 BRZ
Exhaust all finished up and parts are off to get coated! Hopefully turn around is decent, seems I end up waiting forever when I outsource things
gt5759 is offline   Reply With Quote
The Following 5 Users Say Thank You to gt5759 For This Useful Post:
blsfrs (09-11-2023), Jdmjunkie (09-11-2023), RedReplicant (09-11-2023), Ultramaroon (09-11-2023), Wally86 (09-14-2023)
Old 09-18-2023, 10:58 AM   #101
gt5759
Drives: 2017 BRZ
Dash is mounted, canbus pad fitted and starting the process of placing items in the car. Got the wing and mounts finalized but I have it all apart with paint drying or there would be pics of that.
The Following 2 Users Say Thank You to gt5759 For This Useful Post:
Kelse92 (09-18-2023), RedReplicant (09-18-2023)
Old 09-18-2023, 06:29 PM   #102
Koba
Drives: 2020 BRZ
I am sorry if I missed it earlier in the thread... where did you get the dash? Link, if possible.
Thank you!
Koba is offline   Reply With Quote
Old 09-18-2023, 08:29 PM   #103
Kelse92
At the track
Drives: '14 FRS - Former e92 M3
Thank you!
It looks like the Fiberglass HGK dash, but I'll let OP confirm or not
#ladydriven Nasa TT4 FRS // JRZ RS Pro // Karcepts Sway Bars // K24 Swap (in Progress) // AP Endurance BBK // Cobalt Friction brake pads // Safeplace Auto
Kelse92 is offline   Reply With Quote
Old 09-19-2023, 11:09 AM   #104
gt5759
Drives: 2017 BRZ
Thank you!
Kelse92 is correct, its from HGK racing. I was going to order direct until I found drift hq stocks HGK products. https://drifthq.com/collections/hgk-...ts/dashboard-3
The difference in weight is ounces but the carbon one is a 2.5 times the price of the frp one. I imagine it looks immaculate as the frp one is amazing quality.
Kelse92 (09-19-2023), RedReplicant (09-19-2023)
Old 09-19-2023, 02:40 PM   #105
Kelse92
At the track
I can confirm, I have the carbon one and it looks great, but it came with my car. If I was buying new I probably would go with the FRP as well.
What was drift HQ's turnaround time, fairly quick?
The Following User Says Thank You to Kelse92 For This Useful Post:
RedReplicant (09-20-2023)
Old 09-20-2023, 10:10 AM   #106
gt5759
Drives: 2017 BRZ
They were great, it was in stock (they carry quite a few HGK products in stock) and shipped out the next day - it comes truck freight and in a huge crate. I had it in about 3 days. Communication was fantastic as well, emails with status update and tracking.
Kelse92 (09-21-2023), RedReplicant (09-20-2023)
Old 10-02-2023, 05:33 PM   #107
gt5759
Drives: 2017 BRZ
Lots of small things coming together slowly. Instrument display and mount is done (no pic because I'm a dummy). Wing mounts are finalized, and I just need to hand finish some of the milling to make it look like the render.
I still need to mill the hex's with a 45*, bull nose the front edge and cut the trailing edge at 60* then paint or anodize.
With all the testing/simulations and redesigns we got them down to 5.5lbs each and supporting 1klbs. I'm pretty proud of what we accomplished on this part!
Moch up photo.
blsfrs (10-02-2023), ChaseTheFox (10-03-2023), DocWalt (10-02-2023), RedReplicant (10-03-2023), Wally86 (10-06-2023)
Old 10-02-2023, 08:41 PM   #108
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
I know that you want to reduce weight. Are the "holes" in the brackets going to create any kind of vortex problem. At speed, it might disrupt the space/time continuum.
Old 10-03-2023, 10:30 AM   #109
gt5759
Drives: 2017 BRZ
Right! In all seriousness I have no idea for now. We will use flow paint when testing starts so we might get an idea what it does or at least see big issues. I would really like to take this car to the A2 wind tunnel for testing at some point but that's a ways off for now.
The Following User Says Thank You to gt5759 For This Useful Post:
blsfrs (10-03-2023)
Old 10-09-2023, 11:37 AM   #110
gt5759
Drives: 2017 BRZ
After some debating on doing the milling and creating a ginormous mess..........
but it was worth it!
and the weight test
The Following 10 Users Say Thank You to gt5759 For This Useful Post:
autoracer86 (10-09-2023), blsfrs (10-09-2023), DocWalt (10-09-2023), Jdmjunkie (10-09-2023), Kelse92 (10-13-2023), Lantanafrs2 (10-17-2023), M0nk3y (10-09-2023), RedReplicant (10-10-2023), RT-BRZ (10-09-2023), villainous_frx (10-10-2023)
Old 10-30-2023, 01:52 PM   #111
gt5759
Drives: 2017 BRZ
Starting to gain some momentum again on assembly. Got the engine bits and exhaust back from the coater (super pleased), plus the wing mounts are done. Started getting things mounted in the cabin such as the rear view monitor, switches, radio and finishing the dash mounting so it just pops out in a few seconds for servicing. Lots left to do!
Need to figure out my phone and how to take pictures while I'm at it
The Following 6 Users Say Thank You to gt5759 For This Useful Post:
blsfrs (11-01-2023), Code Monkey (10-31-2023), Jdmjunkie (10-30-2023), redlined600 (10-31-2023), RedReplicant (10-30-2023), villainous_frx (10-31-2023)
Old 11-20-2023, 01:01 PM   #112
gt5759
Drives: 2017 BRZ
Little more done recently, trying to work on it between everything else when I can. Any progress is better than nothing!
Pretty much everything is bolted in the car now and only really have the front splitter, windows and then wiring/plumbing. Still need to order the driver's seat (containment style) and move the one currently in the car to the passenger side, along with doing the harness mounts for the passenger side (we plan on doing some things like SORC, silver state classic, mini rallies and everyone likes ride alongs ) It's been fun making everything balance out while keeping room for a passenger.
Received some long-awaited jewelry from Apex on Friday and I have to say they are worth the wait, very impressed by the quality. Superlight, strong, attractive. Apex has really done their work on the design and fitment for these vehicles. I was expecting the additional 5mm offset would cause problems with my current setup but was pleasantly wrong! Biggest thing for me is to see the difference with is the knurling on bead seats as I have fought tire rotation/slippage for a long time.
Gotta love black Friday/week sales!
blsfrs (11-21-2023)
Jensen NASA ST4 race build thin2win Member's Car Journals 18 04-14-2021 12:15 AM
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 07:52 PM
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
Superpenguin's "Not Another Build Thread!" Build Thread superpenguin Member's Car Journals 7 06-17-2015 04:00 PM
Car 986 Scion FR-S NASA PTD Race Car Build phastafrican Member's Car Journals 70 01-03-2015 09:32 PM
