05-16-2014, 08:32 AM | #1191 | |
Pissin off regressives
Drives: They have engines.
Any opinion on the Under braces? Cusco seems to have one for every hole they could bolt one to. I have a high tolerance for noise, clunking, and maintenance. Is understandable that to make the car "better" I have to live with the inherent discomfort of certain parts. Some people were not recommending the Beatrush rear diff brace for daily drivers, but I enjoy mine and haven't noticed any increase in NHV. Have experience with spherical bushings. Had some of them on my Civic on the trailing arm, rear LCA and front upper and lower control arms, but it was a car that never saw rain (no wipers) much less snow and I could have driven it everyday if I could, and it was noisy and shaky. But if the difference between spericals and durometer/urethane in this specific car are negligible, I would prefer to stick with the latter. Thanks |
05-16-2014, 10:00 AM | #1192 | |
Drives: Used to Drive:Grand-Am GS #54 E36M3
The Following User Says Thank You to dradernh For This Useful Post: | CSG Mike (05-16-2014) |
05-16-2014, 11:01 AM | #1193 | |
Basically they make an agreement so that the state can administer vehicle and motorsports laws on the property. The belt laws for NJ Race cars are actually more stringent in terms of time they are valid than what the regs are for all organizations. We've seen the NJSP pull race cars due to out of date belts, even though the belts were in compliance with the sanctioning body. Totally weird stuff. -mike |
The Following User Says Thank You to AZP Installs For This Useful Post: | CSG Mike (05-16-2014) |
05-16-2014, 12:17 PM | #1194 | |
05-16-2014, 12:19 PM | #1195 | |
I haven't driven a FRS/BRZ with all poly bushings, yet, only spherical or stock. |
05-16-2014, 01:13 PM | #1197 |
driving smoother faster
Drives: Sold
05-16-2014, 01:20 PM | #1198 |
Off Topic
It seems like everyone only does drivetrain bushings (engine/trans/diff mounts) and then specific suspension bushings like Whiteline's camber and caster kits. I know energy suspension has a kit for ~$50 that replaces all the front suspension bushings with polyurethane, and one for the rear for about $100. That's not a lot of money, so it's very tempting. I've heard energy suspension isn't as high as durometer as Whiteline, but it's still higher than OEM. I'm a little daunted by the amount of work involved and my ability to do it all in my garage in a timely manner though.
The Following User Says Thank You to gramicci101 For This Useful Post: | Talus1 (10-10-2014) |
05-16-2014, 03:54 PM | #1199 | |
Adjust toe to suit your taste; I personally run 0 all around, as do a lot of locals. |
05-16-2014, 03:55 PM | #1200 | |
I'd recommend leaving everything alone until we have some more data from those that commit to doing bushings regardless. |
The Following User Says Thank You to CSG Mike For This Useful Post: | SirBrass (05-16-2014) |
05-16-2014, 11:32 PM | #1201 | |
Drives: 2013 WRB BRZ Limited
Also, I guess I don't quite understand as much as I thought, but what kind of tire temps should I be aiming for? And what would you recommend for hot tire pressure on the RE-11As? |
05-16-2014, 11:48 PM | #1202 | |
Outer edge higher = need more camber. Inner edge higher = need less camber Center too high = lower pressure. Center too low = lower pressure Inner higher than outer and center = need less toe (if you can manage it) 38 hot is a good guide; adjust to taste and by temp |
05-16-2014, 11:54 PM | #1203 | ||
Driving Coach
Agency Power bolt-in harness bar Schroth Profi II ASM FE 4 point harnesses with street legal push release, installed to the factory belt mounting points with proper hardware and clip in lap belts for easy maneuvering and removal. Using a HANS device as well (anchors were installed on my helmet after that pic was taken so the tethers are now secured.) I just tracked my BRZ all day today with this new setup and it felt great. Very secure in the seat now, to the point where my driving has improved because I have more feedback through the seat into my body as one unit. I'm comfortable with the added safety on track and both organizing bodies I run with (PCA and Hooked on Driving) have no issues or rules against my setup.
05-17-2014, 12:05 AM | #1204 |
Trust me, I'm the Doctor
How do you shut off the annoying beeping of the seat belt alarm when using the harness?
On phone I am. Therefore, if mistakes I make, Frank Oz blame you should.
Daily Driver: 2014 BRZ 6MT Limited ^GT5 Replay Photo Mode^ |
Similar Threads | ||||
Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 06:23 PM |
Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 12:34 PM |
Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 07:47 PM |
Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) -- General Topics | 11 | 05-31-2012 07:48 AM |
Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) -- General Topics | 20 | 01-10-2012 09:54 AM |
