03-20-2014, 09:56 AM | #1233 |
03-20-2014, 06:37 PM | #1234 |
Drives: 13' Scion FRS MT
Is FT-86 SpeedFactory explicitly recommending that folks coat their headers, for daily or track use? I have no former experience either modifying or purchasing aftermarket headers and I want to make sure I am doing it right.
07' Z4M Coupe | KW Clubsports | AFE Intake | Stromung Mufflers | UUC Shortshifter | Advan RS
15' 228i MSport 13' FR-S | TRD CAI | TRD Catback | UEL Header | OFT Stg 1 | Rota Grid-V | RCE Suspension | Hankook | |
03-20-2014, 07:53 PM | #1235 | |
Both our shop cars are running our header uncoated and see extensive track use which is going to be way higher heat than daily driven cars. ( Silver Car is Catless Version, Red Car is Catted Version ) |
03-20-2014, 07:54 PM | #1236 |
sleep, drive, eat, repeat
Drives: '13 BRZ, '12 Outback
Curious as to why you wouldn't want to coat the catalytic converter? I would think it would be the one generating a good amount of the heat.
03-20-2014, 08:24 PM | #1237 | |
Serial Cone Killer
Drives: '14 BRZ - WRB Premium 6MT
The Following 2 Users Say Thank You to Turkish For This Useful Post: | BigFatFlip (03-20-2014), EpicNameBro (03-20-2014) |
03-20-2014, 09:26 PM | #1238 | |
Drives: Dodge Patitas
Sent from my C6906 using Tapatalk |
The Following User Says Thank You to sato For This Useful Post: | BigFatFlip (03-20-2014) |
03-20-2014, 10:28 PM | #1239 | |
Drives: Sci FR-S, Fer F355, Toy Highlander
The cat does it's job by generating a large amount of heat in the catalytic core to burn off the undesirable byproducts of burning the fuel. Coating the cats will reduce the amount of heat that can be dispersed from the core and eventually cause premature failure of the core. The ceramic core could break down and in some cases, could clog the secondary cat and or muffler causing other undesirable issues. |
03-21-2014, 12:48 AM | #1240 |
Drives: ISF
Depends on what eventually is defined as. 2 years? 4 years? I have coated the cat on all my track cars with no issues so far. I just did the UEL as well with my second track day this weekend. Over 500 miles so far. It will be fine.
1993 MR2 Turbo - Red
1996 Supra Turbo - White 2011 ISF - Mercury Metallic / Black Suede 2013 Scion FR-S - Firestorm Red 2014 Lexus GS F-Sport - White / 2015 Lexus RCF - Blue (Nov Delivery) |
03-21-2014, 12:10 PM | #1241 |
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Any a&b, before&after, dynos yet from the new customers??
03-21-2014, 12:56 PM | #1242 |
Drives: '13 Ultramarine FR-S M/T
Check post 1073. In this thread. It doesnt show a base line but it does show the nice flat torque curve.
Mod List:
FT86SF Catted header / Nameless combo pipe with cat and res/ FT86SF V1 CBE / GrimmSpeed Intake / OFT STG 1 GS Tune / Fortune Auto 500's |
The Following User Says Thank You to Sypher For This Useful Post: | kodyo (03-21-2014) |
03-21-2014, 07:38 PM | #1243 |
Just an update on the exhaust leak. It was nothing to do with the header (as I guessed), but one of the gaskets that came with Motiv OP was bad. I replaced it with the OEM subaru gasket that came with the header and she's leak free and sounds AMAZING! WOOO!
The Following User Says Thank You to jonbonazza For This Useful Post: | FT-86 SpeedFactory (03-21-2014) |
03-21-2014, 08:53 PM | #1244 | |
03-21-2014, 09:02 PM | #1245 |
Drives: 2013 WRB BRZ Limited
03-21-2014, 09:17 PM | #1246 |
Tags |
catted uel header, ft86speedfactory header, is my order ready yet? |
Similar Threads | ||||
Invidia Catless and Catted Front Pipe - ** FT-86 SpeedFactory ** | FT-86 SpeedFactory | Engine, Exhaust, Transmission | 107 | 03-29-2016 10:48 AM |
catted header or catted front pipe? | gabeg86 | Engine, Exhaust, Transmission | 28 | 10-13-2015 12:32 PM |
P&l EL catted and coated header. | wootwoot | Engine, Exhaust, Bolt-Ons | 8 | 10-11-2013 12:50 AM |
Catted UEL Header | Cjymiller | Engine, Exhaust, Transmission | 20 | 05-24-2013 12:01 PM |
***Invidia Catted and Catless Front Pipes*** - FT-86 SpeedFactory RELEASE SALE | FT-86 SpeedFactory | Engine, Exhaust, Bolt-Ons | 12 | 10-24-2012 10:12 PM |
