go_a_way1
Old 08-01-2017, 04:41 AM   #1261
TE51
Drives: 1978 Corolla
Originally Posted by ImAdopted View Post
fair enough aha that would be sweet to see more pics though
TE51 is offline   Reply With Quote
The Following 5 Users Say Thank You to TE51 For This Useful Post:
Adam_L (02-26-2018), ImAdopted (08-01-2017), JD001 (08-01-2017), SP86 (08-01-2017), TorontoNat (02-26-2018)
Old 08-01-2017, 10:16 AM   #1262
ImAdopted
Super Saiyan
ImAdopted's Avatar
Drives: 9000 HP FRS
Originally Posted by TE51 View Post
just so amazing aha my inspiration lol
ImAdopted is offline   Reply With Quote
The Following User Says Thank You to ImAdopted For This Useful Post:
TE51 (08-02-2017)
Old 08-01-2017, 11:50 AM   #1263
EnoOnraefi
EnoOnraefi's Avatar
Drives: MY17 Asphalt 86
EnoOnraefi is offline   Reply With Quote
The Following User Says Thank You to EnoOnraefi For This Useful Post:
Old 08-01-2017, 05:55 PM   #1264
SWP
Drives: SWP BRZ
Originally Posted by ssidd View Post
Bronze Apex Arc-8s are so rare around here. I've been looking for pictures. Your car is stunning. Do you mind if I ask what suspension you're running?
SWP is offline   Reply With Quote
Old 08-01-2017, 08:57 PM   #1265
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
Stock is beautiful
DandoX is offline   Reply With Quote
The Following User Says Thank You to DandoX For This Useful Post:
Kronos (05-10-2018)
Old 08-02-2017, 05:30 PM   #1266
ssidd
Drives: 2015 Scion FRS - Asphalt
Haha, Thank You.
Car is sitting on Fortune Auto 500s lowered ~1.3" + SPC Control Arms and Toe Arms in the rear, Camber -2.0F/-1.7R, Toe 0.0F/0.08R.
Took a bit to dial in the height and camber but finally got it to where I'm satisfied. Tho, i kinda want to raise the rear for a slight rake....
ssidd is offline   Reply With Quote
The Following User Says Thank You to ssidd For This Useful Post:
SWP (08-02-2017)
Old 08-02-2017, 05:35 PM   #1267
SWP
Drives: SWP BRZ
Haha, Thank You.
Did you need the rear control arms to return the camber to spec? Or were they installed so you could get extra adjustment?
Old 08-02-2017, 08:15 PM   #1268
ssidd
Yea, need the extra adjustment. With the drop, I was sitting at around -3ish camber in the rear and needed the LCA and Toe arms both to get where I am now. I personally don't see any reason to run more than -2 camber for a daily / weekend track car.
A lot of people have had great luck with the SPC LCA's but I've had a so-so experience. At -2.1 I ran out of toe so got the toe arms and now at -1.7 I am out of camber adjustments.
It's probably due to my ride height, if your around ~1" then SPC should be fine but I initially set it at a 1.3" drop, which tbh might have settled closer to a 1.5...not sure , haven't measured it since setting it cause it looks fine to me.
SWP (08-03-2017)
Old 08-03-2017, 02:11 AM   #1269
Brayden_23
Drives: Asphalt 2015 FRS
I'll leave this here too
Brayden_23 is offline   Reply With Quote
The Following User Says Thank You to Brayden_23 For This Useful Post:
86geek (08-03-2017)
Old 08-07-2017, 10:53 AM   #1270
Cockatoo
TALLY FT86
Cockatoo's Avatar
Drives: 2014 FR-S Monogram -- SBD Turbo --
When that rain hides the dirt...
Cockatoo is offline   Reply With Quote
The Following User Says Thank You to Cockatoo For This Useful Post:
Clipdat (02-26-2018)
Old 02-25-2018, 10:48 PM   #1271
benlaz88
This is what i call AZ sunet
[IMG][/IMG]
benlaz88 is offline   Reply With Quote
Old 02-26-2018, 11:09 AM   #1272
JustSomeGuy
A Nobody
JustSomeGuy's Avatar
Drives: FRS
clean ride! im dumb and cant tell but those 18s? or 17s? lol
JustSomeGuy is offline   Reply With Quote
Old 02-26-2018, 12:23 PM   #1273
ssidd
Thanks, wheels are 17x9 Apex Arc 8s.
JustSomeGuy (02-26-2018)
Old 02-26-2018, 12:34 PM   #1274
JustSomeGuy
A Nobody
Drives: FRS
thats tight, kinda the look im going for but maybe a little more low lol but seems like you have 1 maybe 1.5 finger gap which is slick
DarrenDriven's Asphalt FR-S (sold 1/17/15. Portland OR) DarrenDriven Member's Car Journals 350 05-16-2015 06:45 PM
Asphalt Scion FR-S aznsensazian FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 21 03-17-2014 01:13 PM
Asphalt FR-S pics Rob_g CANADA 24 09-03-2012 05:01 AM
Asphalt 6MT FR-S Symbiont Southern California 22 06-06-2012 07:47 AM
5Hairpins Asphalt MT FR-S 5hairpins Member's Car Journals 13 05-26-2012 12:02 PM
