05-23-2014, 06:21 PM | #1275 | |
Drives: Used to Drive:Grand-Am GS #54 E36M3
The Following 2 Users Say Thank You to dradernh For This Useful Post: | becauseracecar1 (05-25-2014), CSG Mike (05-23-2014) |
05-24-2014, 03:02 AM | #1276 | |
Drives: WRB Premium
05-24-2014, 03:36 AM | #1277 | |
Drives: 2013 BRZ Limited WRB
I have a quick one. How to you countersteer during a slide without turning the car into a 360 with the nannies off. ..
05-24-2014, 12:29 PM | #1278 |
becauseracecar1: Another thing to realize is that "the line" is not the be all and end all of track driving. For a beginner it often becomes a safety blanket that is assumed to keep them on track. Because "the line" seems like a stable, understandable element in a foreign environment, there is a strong tendency to focus on each apex, often to the detriment of other, more important factors. It might feel like hitting your apexes perfectly is the determinant of what a good driver is, or that hitting those apexes might make you a great driver, the envy of all the beginners; it won't.
In reality the line is a placement on track that will be pretty darn good for most cars (assuming they have a good driver) to turn a fast lap time. By realizing that your apexing won't miraculously make you the next Andretti or Senna, you can start to relax about not being perfect. You can start to look up, see what is around you. Those flag stations will be visible much sooner and you will pick up alot more information about what happened in each corner. You will be able to start noticing what happens when you give the car one input vs. another and suddenly the meaning of being smooth will reveal itself much more than anything I, or anyone on this board, can tell you. Being smooth you will see that it is faster to keep a constant lock through a corner and accept being a foot or two off the school line rather than trying to steer onto the optimal path (not to mention you will learn to place the car faster by seeing where it arcs to).
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next! |
The Following User Says Thank You to ddeflyer For This Useful Post: | becauseracecar1 (05-25-2014) |
05-24-2014, 02:48 PM | #1279 | |
Drives: 2022 BRZ Limited
The Following User Says Thank You to glamcem For This Useful Post: | becauseracecar1 (05-25-2014) |
05-24-2014, 06:43 PM | #1280 | |
1) For a rear-wheel only slide, and if there's a significant amount of rear-end step-out, early enough that a tank-slapper doesn't get started because of the amount of countersteer required to catch the initial movement; 2) Very quickly; and, 3) With just the right amount of countersteer. That will fix the 360 problem; whether it arrests the slide in the manner you wish is something else - sometimes you have to get creative with the controls. For example, it's possible for your car to pick up speed while it's in a major four-wheel slide, even when it's on a level section of track; in that case, and if the slide is going to take you off the track, it may be time for two feet in, or some brake and then throttle...whatever works. Obviously, learning this stuff on a race track is a bit dicey - that's why karting, autocross, rally school, winter car control school, etc. are there. |
05-24-2014, 07:49 PM | #1281 |
Thanks
When you are swapping between track and street pads and have to compress the piston, are you opening the bleed screw? If so are you bleeding the brakes a bit after?
How will I know when rotors need replacement? Do I measure them or will it be obvious through braking feel and/or physical appearance?
05-24-2014, 08:35 PM | #1282 |
Assuming the street pads are somewhat worn, then you will probably need to compress the pistons. You don't need to open the bleed valve to compress the pistons, although it would make it easier and if you are planning to bleed anyway, then you can for that.
If you are going to track the car it's a good idea to change out the stock fluid anyway so I would plan on a full flush. Sent from my Nexus 7 using Tapatalk |
05-24-2014, 08:38 PM | #1283 | |
Thanks
I mean in future when swapping back and forth. Sometimes am going to have to press the piston in to fit pads.
05-24-2014, 09:34 PM | #1284 |
Off Topic
An easy way to compress pistons in a sliding caliper, like OEM calipers, is to use a bar clamp to compress the caliper and the bracket before you take the caliper off the rotor. The pistons will be pushed straight in because they're being pushed against the rotor, so you don't need to worry about getting them cocked in the bores.
05-24-2014, 10:33 PM | #1285 | |
You countersteer by, literally, turning the direction is rotating. If the rear is swinging right, you turn right, and vice versa. Just know when to stop coutnersteering, or you'll snap back the other direction and spin the other way. |
05-24-2014, 10:33 PM | #1286 | |
(To the newer guys, don't do this) |
The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | becauseracecar1 (05-25-2014), glamcem (05-25-2014) |
05-24-2014, 10:35 PM | #1287 | |
If you're tracking with race pads, replace the rotors when the microfractures get big enough to make you notice. From the CSG FB page: |
The Following User Says Thank You to CSG Mike For This Useful Post: | ZionsWrath (05-25-2014) |
05-25-2014, 12:30 AM | #1288 | |
Drives: 2013 WhiteOut FR-S
2013 Scion FR-S whiteout 2012 Porsche Panamera S carbon grey 2008 Range Rover Sport SS black - sold 2004 BMW M3 alpine wies - sold |
Similar Threads | ||||
Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 06:23 PM |
Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 12:34 PM |
Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 07:47 PM |
Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) -- General Topics | 11 | 05-31-2012 07:48 AM |
Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) -- General Topics | 20 | 01-10-2012 09:54 AM |
