Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
05-01-2024, 11:43 PM | #1 |
Drives:
Oil cooler install question
So I installed a mishimoto oil cooler. I attached a photo of how I had to install the left fitting to the sandwich plate. I had to have it facing upwards as my turbo is in the way. All the photos ma I’ve seen have it point down. I don’t think this should matter, just want to get someone who is experienced opinion.
05-01-2024, 11:45 PM | #2 |
Drives:
05-01-2024, 11:45 PM | #3 |
Drives:
05-01-2024, 11:46 PM | #4 |
Direction the hose points won't matter. System is pressurized
Sent from my KB2007 using Tapatalk |
The Following User Says Thank You to Ashikabi For This Useful Post: | B00STED86 (05-05-2024) |
05-02-2024, 12:52 AM | #5 |
The direction does not matter. Make sure you torque those banjo fittings correct and you may want to drill them and safety them. Banjo fittings do not perform well with a lot of movement.
The Following User Says Thank You to Grady For This Useful Post: | B00STED86 (05-05-2024) |
05-03-2024, 01:37 AM | #6 |
Wheels for Brains
Seems fine. Just make sure the tension in the hoses tends to pull the fittings toward the tightening direction
The Following User Says Thank You to EndlessAzure For This Useful Post: | B00STED86 (05-05-2024) |
05-05-2024, 03:46 PM | #7 |
Drives:
Thanks for the piece of mind, fellas
Similar Threads | ||||
DIY: Greddy Oil Cooler Install | JBezugs | DIY (Do-It-Yourself) Guides | 30 | 11-16-2022 10:10 AM |
oil cooler install near Seattle? | BRZrkr | Northwest | 0 | 06-08-2022 08:07 PM |
Forrester oil cooler with oil to air cooler question ? | sroby | Engine, Exhaust, Transmission | 20 | 08-01-2019 09:49 AM |
Oil Cooler install in the GTA.. | Skurj | CANADA | 53 | 06-24-2015 02:51 AM |
Help! Oil Cooler Install | brillo | Tracking / Autocross / HPDE / Drifting | 13 | 07-17-2013 04:55 PM |
