Cosmetic Modification (Interior/Exterior/Lighting) Discussions about cosmetic mods. |
08-13-2013, 10:43 PM | #1 |
Drives: Multi colored Scion FR-S
Plasti Dip Problems
Back in June when the Man of Steel movie came out I dipped my car superman themed.
I laid down 4 coats of the blue then I laid the carbon fiber pattern down and did two heavy coats of blaze blue. After that all dried I taped off the shield and put down 3 coats of blaze yellow and then used a darker yellow over that to complete the carbon fiber look again in yellow. Then finished taping the S and sprayed 3 heavy coats of red on top of everything. A week after I had dipped my car I was involved in a flooding and I seized my engine. Insurance covered all expenses but it took about 2 months to get back to me. All that time the car sat in the sun not moving. Anyway I peeled the car today. . . It looks like the red bled thought staining my paint. Has anyone else experienced this or have any ideas on what I can do to remove it. Scrubbing with soap and water does nothing, neither does a pressure wash |
The Following User Says Thank You to SuperJimmyK For This Useful Post: | Flako (08-18-2013) |
08-13-2013, 10:45 PM | #2 |
Yup.
Drives: MT Subaru BRZ '13
I'm guessing the red paint you used wasn't plastidip?
08-13-2013, 10:48 PM | #3 |
All plasti dip. Light blue gallons, blaze blue on top of that, the blaze yellow and plasti dip red for the shield.
08-13-2013, 10:50 PM | #4 | |
Yup.
Try "Dip Dissolver". If you're pressed on time, Goo Gone may work as well. |
The Following User Says Thank You to mikeTee For This Useful Post: | supragoods (08-14-2013) |
08-13-2013, 10:52 PM | #5 |
Drives: 2013 Subaru BRZ
I have no idea how to get that off, and I would probably cry if it were my car. Unfortunately right now I can't help but laugh when I look at those pictures.
Good Luck. |
The Following 11 Users Say Thank You to Flat Black VW For This Useful Post: |
08-13-2013, 10:54 PM | #6 |
Drives: FR-s
Maybe the only way is to sand it or new Hood?
Sent from my SGH-T989 using Tapatalk 2 |
08-13-2013, 11:04 PM | #7 |
Drives: JRSC'd Asphalt FR-S
Oh wow that sucks.. maybe try buffing it with some cutting compound or polish? Good luck
08-13-2013, 11:08 PM | #8 |
Time Traveller
Like the above posters said, just use polish or other paint restoration compounds. It should come out. Alternatively you can just re-dip your hood white for a funky look.
08-13-2013, 11:21 PM | #9 | |
Drives: 2013 Whiteout Scion FR-S 6MT
Just showed this thread to a buddy of mine who works for a local company that Plasti Dips cars. He said...
08-13-2013, 11:25 PM | #10 |
I an not upset about it, and have dipped many other vehicles before without a problem. This is something new though and just wanted to get some input on what everyone thought. I have every intention of dipping it again but might not be doing any decals or extras until I figure out if this was a one time thing or something the clear coat of this car does when dipped. I almost like the ghosted look of the symbol.
I will try the polishing compound and what not tomorrow and see if that helps, thanks for the quick responses. |
08-14-2013, 01:53 AM | #11 |
Drives: 2013 Scion FRS
Does the surface feel raised at all ? try some WD40
08-14-2013, 02:44 AM | #12 |
Drives: 2013 Ultramarine FR-S, 2015 RS 1.0
Just wanted to say that the super man dip was pretty sick looking! Anyway, I would get in contact with someone at https://www.dipyourcar.com/home.php
They might have some suggestions for you if using some rubbing compound doesn't work. I would also try a bit of rubbing alcohol (70% isopropanol) to see if it would come out - I've had good success with rubbing alcohol at getting gunk off the car. Also nail polish remover (acetone) - just don't leave it on your car's paint too long and remember to wash off the acetone afterwards. Also, you can take it to a reputable, professional detailer/restorer. It's really unlikely the dip went through the clear coat, at most it was partially absorbed by the clear coat I think. A professional should be able to take care if it. If all else fails... new carbon fiber hood or vinyl wrap it black! It would look great on white |
08-14-2013, 02:48 AM | #13 |
Drives: Silver Ignition Gundam
Hakuna Montana?
The Following User Says Thank You to IgnitionGundam For This Useful Post: | unsurety (03-27-2014) |
08-14-2013, 02:54 AM | #14 |
Seņor Member
Drives: white BRZ 6MT
rub some kryptonite on it
The Following 35 Users Say Thank You to dori. For This Useful Post: | 4Running Daily (09-22-2013), 636 (12-27-2013), Ahmeda (08-29-2013), Ammonia (08-14-2013), Anomie (11-25-2013), bkblitzed (11-25-2013), Black Tire (03-30-2014), boonFRS (03-20-2014), Brody602 (03-27-2014), BRZ21 (08-15-2013), EAZYBRZY (03-27-2014), ericmpena (03-27-2014), Exhaust (12-01-2013), Froylavin (08-23-2013), Godzilla35 (08-19-2013), hur1ey02 (08-14-2013), Jive Turkey (03-27-2014), jkr (01-12-2014), Khalis (12-03-2013), khan (03-26-2014), meWant (03-26-2014), nix (09-11-2013), Philly758 (08-17-2013), PineappleFriedRice (09-14-2013), sklimo (08-14-2013), smbstyle (09-11-2013), Sportsguy83 (08-14-2013), stefmiesterb (08-14-2013), STS-V (03-27-2014), Takumi788 (07-14-2015), Turkish (08-26-2013), vividracing (11-27-2013), was385 (08-22-2013), Wes (11-27-2013), YDNA (08-17-2013) |
Similar Threads | ||||
Where to get plasti dip done? | Norcalmav23 | Northern California | 22 | 03-06-2014 10:31 PM |
Just another Plasti dip fun :) | EPIKsung | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 4 | 07-17-2013 01:08 AM |
Plasti Dip Professionals | ChandlerSwyng | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 05-25-2013 04:09 PM |
Plasti Dip Vancouver? | Dispect | CANADA | 12 | 11-15-2012 08:44 AM |
Plasti dip on top of a clear bra? | Maps316 | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 10-06-2012 12:32 PM |
