Old 05-02-2024, 07:09 AM   #1
bdtbdtbdt
Drives: 2015 Scion FRS
Rattling noise at start up
I just changed OFT tunes. I went from OFT E85 stage 2 version 4.03 to 93 gas stage 2 v,4.03. I get a very scary metallic rattling noise that seems to be coming from the center of the engine bay for about 30 seconds when I start the car when it is cold. The noise goes completely away after 30 seconds. Car runs normally after that. I have driven over 150 miles since changing the tune. Any help?
bdtbdtbdt is offline   Reply With Quote
Old 05-02-2024, 09:44 AM   #2
bdtbdtbdt
Never mind, Car started normally today. I'm guessing the ECU needed more time to learn the start procedure.
Old 05-02-2024, 01:01 PM   #3
callisto
Drives: 2019 Subaru BRZ
Do you have a recording of the noise?
callisto is offline   Reply With Quote
Old 05-03-2024, 07:17 AM   #4
bdtbdtbdt
Sorry , no recording, At first it sounded like rod knock ,I was devastated. It went away as i raised rpms. Just happened at idle. I am guessing maybe fuel knock from wrong timing advance
Old 05-05-2024, 01:01 AM   #5
tomm.brz
Drives: brz 2017 hksv2
... just the normal cold start at low temperature?
Old 05-05-2024, 06:55 AM   #6
bdtbdtbdt
I wish. It was loud and terrifying, thank god it stopped. Although I drove a hundred miles or more, I only had 2 engine starts since changing tunes. Thinking that the ecu starting and warmup learning had a glitch. Thanks all for this forum, it's great!
Old 05-10-2024, 02:34 AM   #7
callisto
How cold/warm was it outside?
Do you have any exhaust customizations?
How’s your dipstick looking? (Seriously)
Old 05-10-2024, 07:40 AM   #8
bdtbdtbdt
Cool, 40 degrees
OFT header UEL, and down pipe
Fresh Mobil1 5w-30. 1/2 qt high on the dipstick, lots of track driving.
It has positively stopped making any strange noise at start up since
Rattling noise coming from car? YgRoshi Scion FR-S / Toyota 86 GT86 General Forum 8 04-22-2019 06:32 PM
Rattling noise on a stock BRZ? merdok12 Engine, Exhaust, Transmission 22 10-25-2016 05:58 PM
Rattling noise Eighty 6 Scion FR-S / Toyota 86 GT86 General Forum 4 06-07-2016 11:54 AM
Loud Rattling Noise at Start Up tomaszjanczak Issues | Warranty | Recalls / TSB 43 09-18-2014 08:50 PM
Rattling noise under Acceleration 5k RPM or more phuthinhon Issues | Warranty | Recalls / TSB 5 05-12-2014 12:34 AM
