Old 07-19-2012, 12:23 PM   #15
bneale
bneale's Avatar
Drives: Scion FR-S
Originally Posted by HunterGreene View Post
Thank you Azain! Currently downloading
The signup takes 5 seconds. Just do it.
Sorry but no. I don't like spreading my info around the internet just to download 1 file. Call me parnoid, but I try and avoid this at all costs.
It's not worth signing up in my opinion. I'd rather look else where for the same file. I'm greatful for the fact the OP posted this but there must be a better way to do this. What about an ISP server space for webhosting? I used to use my free 5megs (or whatever it was) for this kinda thing all the time.
bneale
bneale is offline   Reply With Quote
Old 07-19-2012, 12:32 PM   #16
ahausheer
Re-member
Drives: Toyota camry
Downloaded. I converted it to a straight PDF, all 1,750 pages. This resulted in a 58-MB file. The sections remained grouped but are out of their original order and I am not going to reorder 1700 pages. There is no Table of Contents, but the PDF is searchable so its not bad. Resolution is good. The PDF is hard to navigate though because there are no page numbers or headers. Ill use this as a reference but will continue to look for something more user friendly. To the OP thank you for posting, I imagine this took a lot of work.
EDIT: Converting to PDF causes pages/sections to be out of order to the point of making it difficult to use. I will personally not use the PDF but will try the PDF Portfolio. Also note, I have a blazing fast computer and the Portfolio still needs quite a bit of time to load.
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 07-19-2012, 12:35 PM   #17
smbrm
smbrm's Avatar
Drives: Scion FRS Ht Lva(AT)
Originally Posted by cmspooner View Post
Some of the sections (at least I found some in the engine mechanical section) at broken. They have a single page with the following text:
Concurrent Login Alert
Someone has logged into a second PC using your username and password.
Password access to this system is limited to an single user for each user ID. You are responsible for the confidentiality of your user name and password.
Please Note: You must re-start your browser before attempting to login again to properly clear your session. Click the "X" in the top right corner of this window to close your browser. Then open a new browser window and try your login again.
Toyota Motor Sales, Inc
Thanks, but I found the same issue, just reporting.
smbrm is offline   Reply With Quote
Old 07-19-2012, 12:44 PM   #18
azian_advanced
*****istrator
azian_advanced's Avatar
Drives: 2013 Scion FR-S 10-Series M/T
Update: added file to MediaFire upload server
I forgot to mention, the links are not accessible without a (paid) TechInfo account. All the links are supposed to do is redirect you to another section of the manual that was already covered to avoid having to add the same material twice. You will have to manually navigate to the corresponding sections yourself.
If someone is willing to reorganize the pages so they're in one single document instead of a portfolio of multiple documents and send it to me, I can add it to the OP.
azian_advanced is offline   Reply With Quote
The Following User Says Thank You to azian_advanced For This Useful Post:
whataboutbob (07-19-2012)
Old 07-19-2012, 01:47 PM   #19
bneale
bneale's Avatar
Drives: Scion FR-S
Thanks for adding the second link. I appreciate it very much!
bneale
Old 07-31-2012, 12:21 PM   #20
Surakusa
Mechanical Guru
Surakusa's Avatar
Drives: 2013 Scion FR-S (Argento) M/T
I just combined all the pdf documents into one manual... There is about 4700 pages total. I'm going through now making each page "searchable" with OCR. Though the chapters/bookmarks are out of order... They are infact in Alphabetical order based on the file naming structure. I don't foresee this to be a problem as long as OCR is on each page. Thread starter Azian_Advanced, PM me your info, I can make this available in dropbox if needed and post this as a link as well?
Surakusa is offline   Reply With Quote
The Following 2 Users Say Thank You to Surakusa For This Useful Post:
civicdrivr (07-31-2012), ultra (08-05-2012)
Old 07-31-2012, 01:14 PM   #21
Surakusa
Mechanical Guru
Surakusa's Avatar
I have some linux skills. So I'm going to split up each file and possibly be able to put everything in it's proper order using some bash scripting... This is just theoretical at the moment. there are about 1700 different pdf files. (according to the PDF viewer) when I split them up... But if there is a logical order of extraction... I might be able to make this work.
The Following 3 Users Say Thank You to Surakusa For This Useful Post:
azian_advanced (07-31-2012), civicdrivr (07-31-2012), ft86Fan (08-01-2012)
Old 08-03-2012, 03:59 PM   #22
Surakusa
Mechanical Guru
Surakusa's Avatar
On a related note... If I have time this weekend... I'm going to just do a grab of each page from the tech site. That way we will have all the pages.
Note: This is in response to the issue with some of the pages missing with a login error.
azian_advanced (08-03-2012), cmspooner (08-03-2012)
Old 08-05-2012, 02:35 PM   #23
Surakusa
Mechanical Guru
Surakusa's Avatar
Just giving an update... This is taking much longer than expected... I'm looking at the techinfo site... and there is no easy way to perform a script to get all the urls I want. ( Or at least I'm not good enough to do it that way) So for now... I'm just going through each section and pulling one by one... This is taking a while... If only I had like 10-15 members that would volunteer to grab all the data in a specific section haha. :P
The Following User Says Thank You to Surakusa For This Useful Post:
civicdrivr (08-06-2012)
Old 08-06-2012, 12:16 PM   #24
Surakusa
Mechanical Guru
Surakusa's Avatar
Daily Updates: I am not going into the Engine Section... I might have to purchase another 2 days to work on this... XD It takes a lot of time... I'm being very thorough... As I am going through this... I noticed that in the info links... there is a lot of redundancy, which hopefully I can merge all of that information (if it's even needed) and we'll be good to go.
Old 08-07-2012, 12:01 AM   #25
Surakusa
Mechanical Guru
Surakusa's Avatar
Update: I Finally viewed the entire Repair Manual. I have half a day left till my 2-day subscription ends. I'll see if there is anything else that is worthy. I'll hopefully have it all built up by the end of the week.
Last edited by Surakusa; 08-07-2012 at 12:03 AM. Reason: Cleaned up the sentences a bit lol.
The Following 4 Users Say Thank You to Surakusa For This Useful Post:
civicdrivr (08-07-2012), cmspooner (08-07-2012), ft86Fan (08-14-2012), Sithspawn (12-30-2012)
Old 08-13-2012, 12:48 PM   #26
Surakusa
Mechanical Guru
Surakusa's Avatar
I sent the info the the OP last week, he/she just has to update his post.
Known do-it-yourself mechanic. "If you have the drive, you can learn..."
"The left lane is meant for fast passes, not slow asses..."
The Following 5 Users Say Thank You to Surakusa For This Useful Post:
civicdrivr (08-14-2012), JTM (08-13-2012), mid_life_crisis (12-26-2013), normancw (12-24-2013), SVXdc (10-04-2012)
Old 08-13-2012, 04:21 PM   #27
azian_advanced
*****istrator
I'm currently uploading the file but may take another couple of hours before it's ready. I quickly skimmed through it and it is really well put together! Well done Surakusa. The OP will be updated shortly.
edit: Whoa 5009-page file!
Old 08-13-2012, 11:07 PM   #28
azian_advanced
*****istrator
Updated the first post and added Surakusa's version of all 5009 pages into a single PDF. The Table of Contents are useless in this version but use Ctrl + F to search by keyword for faster navigation. This runs MUCH FASTER and SMOOTHER than the PDF portfolio that I initially uploaded before.
Also, a bookmarked version of the same file is in the works!
The Following 3 Users Say Thank You to azian_advanced For This Useful Post:
civicdrivr (08-14-2012), ft86Fan (08-14-2012), Zagmeister (04-16-2013)
manual, repair, service
2013 Subaru BRZ Factory Service / Shop Manual Hachiroku DIY (Do-It-Yourself) Guides 36 02-10-2020 03:04 PM
2013 Subaru BRZ Factory Service / Shop Manual Hachiroku Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 103 06-21-2019 08:57 AM
Factory Service Manual Brett Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 25 06-10-2012 11:12 PM
NW Shop Review: AR Auto Service/Adrenalin Racing (Lake Oswego OR) DarrenDriven Northwest 0 06-04-2012 12:57 PM
