Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
12-16-2013, 12:04 PM | #15 |
I also contemplated this same scenario with my car. In the end I just invested in some stance coilovers. If money plays some kind of factor hit me up and I can make sure you get your money's worth no matter what direction you go.
The Following 2 Users Say Thank You to vividracing For This Useful Post: | 1086 (12-16-2013), suaveflooder (12-16-2013) |
12-16-2013, 12:09 PM | #16 | |
@1086, another thing you might want to think about is wheels. If you ever want aftermarket wheels, 9.5 inch wheels (which is what I'm looking at) won't fit with the stock perch. I bought my springs a month after my car and LOVE how it handles and looks, but I want some wide wheels and they won't fit on the current set up. Like mentioned, don't cheap out, if you decide to go coil over. |
12-16-2013, 02:07 PM | #17 |
Drives: UM86 - 6MT
If I were to get wheels, I would probably only go 8 inches width max. For now I am happy with the stock wheels though.
So did you add the 20 mm spacers first before dropping it with the eibachs? or did you add spacers and added shocks at the same time? Would you agree that if I go the route of stock struts + eibach pro kit + 20 mm spacers all around that I will be fine, especially on relatively harsher turns? I just don't want any rubbing or something to eff up is all. Plus, if I have to replace the stock struts with Konis eventually, that is completely fine. Last edited by 1086; 12-16-2013 at 02:29 PM. |
12-16-2013, 02:46 PM | #18 |
Drives: 04 Toyota Tacoma Prerunner Reg Cab
I've been curious on the Tein's cheaper offerings/models too as compared to Lowering Springs + Koni's/Tokico's.
Specifically: Are the Tein Street Basis shocks/struts short-stroke??? If, yes, then I would assume that the cheap Tein Basis setup would be much better than a lowering spring (eibach, tein, etc. etc) + koni/tokico combo for this reason alone; and would also be in a very similar price range to each other. |
12-16-2013, 03:04 PM | #19 | |
12-16-2013, 04:51 PM | #20 |
Drives: waiting on a 2021...
I have Eibach Pro's on stock struts. 40K on the car and no problems. I have aftermarket rims, but with any rim flush in the wheel wheel it definitely makes the car look lower.
2016 4Runner Tail edition
2020 Camry 2020 RAV4 2013 Chevy 3500 4x4 Duramax 1999 Ford F250 Powerstroke, the tow rig 1969 Mustang, the fast car....(: |
The Following User Says Thank You to zooki For This Useful Post: | brz408 (12-16-2013) |
12-16-2013, 11:38 PM | #21 |
IMO with a lower end coilover you are making big sacrifices in the quality of the damper itself. That is the most important part and with a koni set up you get good solid valving. No height adjustability, but I'd rather better valving and a preset drop.
- Andy |
12-17-2013, 01:49 AM | #22 |
Drives: UM86 - 6MT
So you think it would be OK to go with the Eibach pro/RCE on Stock struts or is it safer to go with the Koni + Eibach Pro/RCE?
12-17-2013, 04:18 AM | #23 |
Drives: Nuisance BRZ
Option 2 sounds the best. As racecomp said, you really want your dampers to be up to par. I know others recommend BC BR coilovers but from my personal experience, they aren't great, at all. For looks yea they get the job done but I didn't like the valving (dual adjustment one knob bs). I couldn't seam to get it to feel the way I wanted. ST coilovers is a great other option as it's made by KW. They will also most likely give you the best ride quality out of the sub 1k coilovers.
12-17-2013, 04:23 AM | #24 |
Just a dude
Drives: Scion FR-S 2013
Another thing to note is Konis don't come as a bolt in strut, you need to mod with existing struts. To some that dont have the tools or know how that is something to consider. If you were to go coils and budget minded based on all you've said then go with STs or The lower line Bilstein (or) save up and go a little bigger. As mentioned the "cheap" lines of chinese types coilovers are not going to give you a great ride that you'd be happy with.
12-17-2013, 10:46 AM | #25 | |
The Konis are an improvement for sure but a mild pain to install since the fronts are inserts. I'd be tempted to wait for Bilsteins. I'd prob run Yellows on stock dampers and then put the Bilsteins on when they're out. - Andy |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | brz408 (12-19-2013) |
12-23-2013, 01:27 PM | #26 | |
Drives: 14 FRS Whiteout
Sent from my iPad using Tapatalk HD |
12-23-2013, 01:50 PM | #27 |
I'll take good preset fixed damping over crappy adjustable damping. Every time.
There's a lot more to it than just "soft" and "stiff". - Andy |
12-23-2013, 02:10 PM | #28 |
^^ This, plus just because they're adjustable doesn't mean you have the know how to properly adjust them. I'll take something tested that I don't have to mess with unless you're willing to spend time doing proper testing to see what works well with the damper settings.
Similar Threads | ||||
Weight Reduction (budget diet) for daily/spirited driving | 1086 | Scion FR-S / Toyota 86 GT86 General Forum | 86 | 03-22-2015 01:18 PM |
New to me daily driver.. 95 M3. | Dave-ROR | Other Vehicles & General Automotive Discussions | 58 | 07-17-2014 02:05 AM |
FRS as a Daily Driver? | Pake1 | Scion FR-S / Toyota 86 GT86 General Forum | 104 | 08-15-2012 11:48 PM |
Will the BRZ be your daily driver | WRXGuy1 | BRZ First-Gen (2012+) -- General Topics | 47 | 05-23-2012 12:15 PM |
BRZ as daily driver? | Pakjk89 | BRZ First-Gen (2012+) -- General Topics | 81 | 03-22-2012 09:50 AM |
