05-04-2014, 03:57 PM | #113 |
Driving Coach
Yes, but I'd demand the dealer do it. They can read the code in memory and you can point them to this thread with lots of documentation that P0351 is isolated to the cylinder #1 coil pack.
05-04-2014, 04:16 PM | #114 |
Drives: Rocket Bunny'd GT86
We did all of that, I even had the mechanic hop in with me in the car and did the test, CEL popped up, still convinced that it was a reflash issue, in other words, the whole UAE is complaining about the pointless service centers we have in our dealership, believe it or not, I have to tell them that I am bringing my car in for service a week before I do because the oil is not available instantly, the jacks are not made for lowered cars, the warranty goes off even with a catback exhaust, so let's leave all of that aside and say that I shouldn't be worrying about DI seals failing correct? I should just replace the coil pack that is on the passenger side (my car is LHD) located underneath the black ECU and voila, no swapping like someone stated that brought engine failure to him or anything else, just swap out the old coil with the new coil, correct?
05-04-2014, 04:22 PM | #115 | |
Driving Coach
Yes, I replaced the same coil myself and it wasn't too difficult, just need hand tools and patience. I have more details in this thread a few posts back. You should be able to replace it yourself just fine, just remember to stuff some rags below to catch any dropped bolts. |
05-04-2014, 04:28 PM | #116 | |
The Following User Says Thank You to Yamajee For This Useful Post: | ATL BRZ (05-04-2014) |
05-12-2014, 10:36 AM | #117 |
Master Troll
Drives: 2013 BRZ Limited
Just got this on cyl 1 at the global time attack this past weekend. Going to take it in and hope they will replace the coil pack. My only mods are power blocks, K&N and exhahust. NO tune. 93 oct gas, 38k miles boughti n June 2012.
05-12-2014, 11:06 AM | #118 |
Driving Coach
#1 coil failure seems to be an inevitability for those who track their cars.
05-12-2014, 01:45 PM | #119 |
Dodging cones
Drives: 2013 BRZ Limited, 93 Z28
Hopefully you didn't clear the ECU as they will need to see it in memory before they replace it typically.
Also, be aware that when they pull it, they see RPM and speed readings. I had a service manager bitch at me because I was doing 98. I told him up front though that I was passing a semi on a 2 lane road and traffic pulled into the oncoming lane (honest truth about the CEL I had the day before I went to dealer). They may question the power blocks if they notice, even though we all know this is a problem on 100% stock cars.
05-12-2014, 02:18 PM | #120 |
Master Troll
I already cleared it. If it pops up again I'll leave it and bring it in. Thanks.
Sent from my XT1080 using Tapatalk |
06-24-2014, 07:56 AM | #121 |
Drives: 13 BRZ, 97 e36 M3 Rides: '07 600RR
Had the same issue this past weekend at the track. P0351 error, so I cleared it and jiggled the wires. Next run session it didn't come back, but I also kept the rev's below 7k rpm this time around (instead of shifting at 7400-7600 - ecutek tune). All seems well so far but I took a video of the error code before I cleared it. Hopefully subaru will replace the coil pack as well.
06-24-2014, 02:00 PM | #122 | |
Coil packs are $80, and I don't run that many events, so hopefully I can get a year out of one. Kind of insignificant compared to the rest of the track expenses. |
06-24-2014, 02:06 PM | #123 |
Dodging cones
Trick to clear it without erasing from memory (to gain CC back) is restart the engine three times, with a few minutes of drive time between each restart. Seems to clear it for me. Within 10 minutes of getting that CEL, I could have my CC back
06-24-2014, 02:38 PM | #124 |
Drives: Hydra EMS Powered FRS Raven Black
I never had a problem with any of my coil packs on my original FRS engine and wiring. When I swapped in a BRZ motor, wiring harness, etc after my fire I had coil pack 1 go bad and it actually left me stranded on the side of the road.
When I pulled it there was melted plastic on the inside like the spark was jumping through the coil pack to the head. This is actually what it was doing as I was blowing a the "Ign" fuse kept blowing the moment you would crank the engine. Wish I had a picture but it appears I tossed it in the garbage. |
06-30-2014, 09:44 AM | #125 |
Drives: 2014 Wrb Brz limited 6m
I just pulled this code on my car too. Also seems to stumble some times as well. Where can I buy a replacement coil?
06-30-2014, 09:47 AM | #126 |
Driving Coach
Subaru parts warehouse dot com
Similar Threads | ||||
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset | GC GTS Aero Kit | Australia Classifieds | 16 | 03-22-2013 05:49 AM |
Which Markets have "GT86" and "Toyota" badges on trunk? | Tanuki | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-10-2013 05:23 PM |
Anyone else try running "square" tires on "staggered" wheels? | hamlet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 12-19-2012 12:59 PM |
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
Shutting off your "key-in-with-door-open" beeper -- it's very easy | avusblue | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 08-13-2012 05:29 PM |
