Engine Swaps Discussion of engine swaps. |
03-05-2023, 08:39 AM | #99 | |
Meow
Drives: GT86, Volvo 996
LS7s do rev to 7.1 stock so a few improvements could get you there ! Gearing might be a bit tall then? Like almost 200kph in 3rd? |
03-05-2023, 11:17 AM | #100 |
Drives: 2013' Toyota 86 (EU spec)
We will see. As long as it doesnt need to be a lower ratio everything is fine. Im on 3.58 currently, whats lowest ratio for the factory diff. For higher ratios plenty gear sets are available to choose from.
Tags |
cad, diy, ls swap, ls3 |
Similar Threads | ||||
2JZ Swap - Looking for Labor Info from Swap Shops/XP'd Members | Cookiemonster | Engine Swaps | 18 | 05-25-2019 12:40 PM |
Dead RB25 Swap, Alive 2jz swap | -Phil | Engine Swaps | 72 | 09-15-2018 02:35 PM |
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 10:54 PM |
Ls or 2jz swap? | sgoldberg01 | BRZ First-Gen (2012+) -- General Topics | 13 | 03-22-2016 03:07 PM |
