Old 02-02-2022, 04:15 PM   #15
Four_wheel_drifts
Drives: Whiteout track car; lava donor
[QUOTE=Ashikabi;3501400]20k later
New, old stock FA20 long blocks are about $9k from non-dealer sources. If I remember correctly, the price through a dealer is at least two times that.
So unless the FA24 is coming from a crashed gt86 (IAAI had one a couple of weeks ago), the longblock alone would be over $20k through a dealer.
I hope I’m wrong and that Subaru/Toyota sells the new engines for more reasonable prices ala spec Miata motors through Mazda’s racer support program.
Four_wheel_drifts is offline   Reply With Quote
The Following User Says Thank You to Four_wheel_drifts For This Useful Post:
jeepmor (01-09-2024)
Old 02-02-2022, 07:10 PM   #16
RedReplicant
Drives: None
To be fair, Mazda Motorsports pricing is a beautiful gift that seems unmatched by anyone else. Man, the bodywork prices and shipping pricing on them... perfection.
RedReplicant is offline   Reply With Quote
Old 02-02-2022, 07:18 PM   #17
Ashikabi
Ashikabi's Avatar
[QUOTE=Four_wheel_drifts;3501727]
20k later
I assumed the motor was from a wreck. I'm assuming the swap itself with a "free" motor will still cost an arm and a leg. Probably a few fingers too. It's not like a 90s Honda where literally everything bolts up and you just have to swap a couple connectors.
Old 02-02-2022, 09:46 PM   #18
BrahmaBull1990
Howdy
BrahmaBull1990's Avatar
Drives: 2020 BRZ PP
Originally Posted by RToyo86 View Post
I wouldn't agree to anything unless you can get the price on paper guaranteed.
Otherwise you are at their mercy as things come up and the bill starts to inflate.
Isn’t there a guy here that has $40k in a car and the shop has had it for a year? They just keep charging him for stuff
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
BrahmaBull1990 is offline   Reply With Quote
The Following User Says Thank You to BrahmaBull1990 For This Useful Post:
spcmafia (02-03-2022)
Old 02-02-2022, 10:26 PM   #19
Ashikabi
Ashikabi's Avatar
Honestly wouldn't surprise me. The LS swaps have all the bugs worked out and still cost a small fortune
The Following User Says Thank You to Ashikabi For This Useful Post:
BrahmaBull1990 (02-02-2022)
Old 02-03-2022, 01:43 AM   #20
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Honda sells the K20C for fair prices, but not like Miata, who has stated that racing and replacement parts has done a lot to support and justify to the bean counters the continued existence of the Miata.
Old 02-03-2022, 07:22 AM   #21
spcmafia
Drives: 2018 Subaru BRZ
I wonder what happened to that guy. I did see a somewhat same story on Cars and Bids. It was a 2018 BRZ with less than 20K miles with an LS swap. Didnt make the reservation but the background story was similar, owner purchased vehicle and immediately went for the swap.
The Following 2 Users Say Thank You to spcmafia For This Useful Post:
BrahmaBull1990 (02-06-2022), soundman98 (02-03-2022)
Old 09-05-2022, 08:08 PM   #22
jeepmor
Drives: 84 CJ7, 08 Duramax, 2014 FRS
LOL, just boost you're FA20 and move on. More power, less headaches than a full swap. Want to go crazy, swap in the WRX block with lower compression so you can play with a wider range of boost, and put in some good rods like Manley or Skunkworks. IAG uses Manley and only does oil mods and better tolerance machining.
No new crank, pistons, etc, just rods and it becomes 600hp capable. Your engine problems will start here and give usual head gasket issues because open deck cylinder long blocks tend to walk around when at their limits and break the head gasket seals.
For reference, Toyota made BMW produce a closed block system on the Supra instead of just running with one of the off the line bimmer motor. Good call.
jeepmor is offline   Reply With Quote
The Following User Says Thank You to jeepmor For This Useful Post:
twasd (11-29-2023)
Old 09-05-2022, 08:58 PM   #23
PulsarBeeerz
Drives: JRSC BRZ SOLD
You can't swap in a WRX block. Different bell-housing and starter mounting points. Rods and pistons are all that is needed. But after 350whp one runs into transmission issues.
PulsarBeeerz is offline   Reply With Quote
The Following 4 Users Say Thank You to PulsarBeeerz For This Useful Post:
jeepmor (01-09-2024), NoHaveMSG (09-05-2022), twasd (11-29-2023), Wally86 (09-05-2022)
Old 01-09-2024, 10:28 PM   #24
jeepmor
My mistake, I was told they were the same long block sans the compression ratios. Just the long block portion, not the rest. Didn't know the starter was an issue.
FA20 vs FA24 Zata Engine, Exhaust, Transmission 15 06-01-2023 10:18 AM
Supercharged FA24 knapper Forced Induction 11 12-16-2021 01:14 AM
FA24 In-Depth Look Kona61 GR86 General Topics (2nd Gen 2022+ Toyota 86) 36 10-11-2021 08:27 AM
Second Gen Swap? FA24 AutoNewb Engine Swaps 86 07-06-2021 10:55 AM
FA24 Mix n Match RiceCracker86 Engine, Exhaust, Transmission 1 04-18-2019 03:59 PM
