Old 12-16-2023, 09:56 PM   #57
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by kmbkk View Post
They wouldn’t give me any further details. I assume they worked it out before offering swap packages, but I don’t have proof of it unfortunately
If they are not willing to give more info I wouldn’t trust it.
Swapping the short block with FA20 heads just seems like the wrong way to go about it to me. Complete FA24’s with transmission(also supposedly improved) are under 7k. Seem’s like it would be easier to go that route and work out what needs changed so the ECU can read the sensors it needs to run. If I had a bigger budget I’d have a complete FA24 in my garage right now. We already know about 99% sure that it is using the same signal type as the 17’+ cars for cam and crank position. Merging the engine harnesses, or building new crank and cam reluctor along with swapping to the FA20 crank sensor(pre 17’ cars) seems like it would be less intrusive.
The Following 5 Users Say Thank You to NoHaveMSG For This Useful Post:
new2subaru (12-17-2023), peachch (05-13-2024), Spuds (12-16-2023), Tatsu333 (12-17-2023), Teseo (12-17-2023)
Old 12-17-2023, 04:36 AM   #58
tomm.brz
Drives: brz 2017 hksv2
i dont think 7k is with trasmission..link?
usually 7k is tge long block complete but without transmission
Old 12-17-2023, 11:58 AM   #59
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Can’t find one right now. The first one I thought I found didn’t include trans but it was pictured. If I find another I will link it. There were over half a dozen FA24’s engines on eBay a few days ago but now there are not many.
Old 12-17-2023, 01:33 PM   #60
tomm.brz
ok i thought u were talking about official subaru prices
Old 12-17-2023, 02:32 PM   #61
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
From what I recall from Opie’s thread, he couldn’t buy an FA24 short block without a VIN. I am sure that will change in the future when availability is a bit better.
Also noticing that FA24DIT(turbo) engines are much cheaper, just the FA20DIT.
Old 12-18-2023, 06:51 PM   #62
jflogerzi
jflogerzi's Avatar
I talked to a shop this weekend who’s already done this swap. They’ll do a swap, complete with a new FA-24 long block, for around $7k. This assumes your car is in good working condition, as they use existing parts from your car. If it wasn’t so far away (the shop is in WI and I’m in VA) I’d probably already have my car there.
that sounds wayyyy to cheap.... but if this is the case I know what I am saving for
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
Dadhawk (12-18-2023)
Old 12-20-2023, 04:42 PM   #63
I wish new long blocks were that cheap!
Old 12-21-2023, 04:21 PM   #64
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
It’s actually a short block, not a long block. They use your existing FA20 heads.
kmbkk is offline   Reply With Quote
Old 12-21-2023, 09:36 PM   #65
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I measured a set of FA20 heads a while back and at the FA24 bore there didn’t seem to be much gasket space. I’ll have to check again when I pull another engine apart here in another month or so.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
kmbkk (12-21-2023)
Old 12-21-2023, 10:45 PM   #66
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
From what I’ve researched the difference between the heads and block is one of the issues needed to resolve for this to work well.
First autox in my GR86 justinco Tracking / Autocross / HPDE / Drifting 10 05-30-2022 07:52 PM
Why BRZ Over GR86? Lelandjt BRZ Second-Gen (2022+) -- General Topics 45 12-26-2021 08:41 AM
TOM'S GR86 Catalogue DeeAich GR86 General Topics (2nd Gen 2022+ Toyota 86) 6 11-15-2021 12:14 AM
GR86 PCD teppey GR86 General Topics (2nd Gen 2022+ Toyota 86) 23 07-29-2021 11:12 PM
GR86 In R7 of the Toyota Gazoo Racing GT Cup + GR86 coming to Grand Turismo Sport Blighty GR86 General Topics (2nd Gen 2022+ Toyota 86) 37 07-18-2021 03:38 PM
