Old 10-06-2021, 01:32 AM   #85
AndMsc
Drives: MY2018 GT86
Hello guys,
Which one between Hypergram and Dekagram do you think is more performant (as in more durable)? In 17x9 +40 they are the same weight and cost the same.
For GT86 with PP Package.
Thank you,
Andrei
AndMsc is offline   Reply With Quote
Old 10-15-2021, 11:32 PM   #86
jflogerzi
jflogerzi's Avatar
I am partial to the hypergrams. Currently they are my track tires
Sent from my Pixel 5a using Tapatalk
2013 Series 10 FRS #553
Old 10-21-2021, 12:10 PM   #87
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Originally Posted by AndMsc View Post
Hello guys,
Thank you,
Andrei
That sounds like a very complicated question to answer. May be worth a shot to ask Konig how the wheels differ in stress levels and which ones are more likely to give at various loads. Otherwise, at the same size, weight, and multi-spoke design, they are probably about equally durable. Just based on their design looks, I would think Dekagrams can provide that extra bit of durability based on their spoke attachment points.
Have you confirmed that the Dekagrams will fit over your PP package? I know Hypergrams will, but I know Dekagrams aren't designed for big brakes necessarily, so they may be cutting it close.
Dzmitry is offline   Reply With Quote
Old 05-02-2022, 12:04 AM   #88
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
I got a set with the machined lip for track use. I'm lowered about 1.25 inches on RCE SS1.
Lynxis is offline   Reply With Quote
The Following User Says Thank You to Lynxis For This Useful Post:
SCFD (05-02-2022)
Old 05-03-2022, 10:15 AM   #89
SuperTom
SuperTom's Avatar
Drives: C5 Corvette, '17 Toyota 86, Jeep XJ
17x9 +40 lowered on coilovers
SuperTom is offline   Reply With Quote
Old 05-03-2022, 08:15 PM   #90
___LUNK
Drives: Laguna Seca Blue GR86
My 2nd gen with 17x8+40
___LUNK is offline   Reply With Quote
The Following 3 Users Say Thank You to ___LUNK For This Useful Post:
Rcode (05-04-2022), SuperTom (05-03-2022), Teseo (05-05-2022)
Old 05-04-2022, 11:53 PM   #91
Rcode
Rcode's Avatar
Drives: Ford Fiesta ST, 2022 Subaru BRZ
The second gen looks pretty good with the Hypergrams! 17x8 is probably the way I'll go as well. I think I've narrowed down my track wheels to these, RFP1's or Dekagrams. Thanks for posting this!
Rcode is offline   Reply With Quote
Old 05-06-2022, 05:37 AM   #92
Kingg
Drives:
They looks good. Still looking for a set
Kingg is offline   Reply With Quote
Old 11-27-2023, 08:36 PM   #93
Vangfrs
Drives: Argento Frs
What are your wheel and tire specs? How many inch drop? Camber?
Fron reading the csg tein flex a and rcc ss1 forum +40 offset has rubbing issues?
Vangfrs is offline   Reply With Quote
Old 12-01-2023, 11:02 PM   #94
Lynxis
Lynxis's Avatar
Wheels are 17x9 +40
Alignment is -3f/-2.2r camber, 0 toe
Tires are Falken RT660 245/40r17
No rub at all, even under hard track driving.
Vangfrs (12-12-2023)
Old 12-12-2023, 11:52 PM   #95
Vangfrs
Drives: Argento Frs
Wheels are 17x9 +40
Thanks, appreciate the reply. Do you have any pics of ur car by chance?
The Following User Says Thank You to Vangfrs For This Useful Post:
Lynxis (12-15-2023)
Old 12-15-2023, 06:50 PM   #96
Lynxis
Lynxis's Avatar
I've got a few.
Old 12-15-2023, 07:40 PM   #97
RippedManiac
Jedi
Drives: Pikachu BRZ
If you go 245 you need coils or you might have tire rub on the oem spring perch.
RippedManiac is offline   Reply With Quote
Konig Rims- what do you think? KatrinaR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 05-25-2015 01:35 PM
Konig Torch 18x8.0 +35 khan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 05-21-2014 12:27 AM
WTB- Konig Daylites solort Want-To-Buy Requests 0 01-07-2014 11:07 PM
Konig Wheels pghfan19 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 04-25-2013 12:24 AM
Konig deception oaroyale Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 02-02-2013 09:02 PM
