01-27-2015, 01:59 AM | #253 | |
Drives: 86
01-27-2015, 11:58 AM | #254 | |
PhoneFlash by EcuTeK
When 2004 arrived and they released the STI, this is when the WRX became a "second class" vehicle under the Impreza lineup and under the EPA rules and regulations were required to run stoich for those 2 seconds. This was not a problem in 2002-2003 because the top of the line Subaru was a WRX at that time. Now with the new 15 WRX it runs in closed loop for even longer but with better A/F ratios, though still not ideal. We are actually tuning the new 15 WRX to run closed loop 100% of the time now, so we can obtain a more accurate and repeatable A/F ratio. This is now something we are testing on the BRZ/FRS/86 platforms for improved response, and more consistent A/F ratios. Cheers, William Knose Delicious Tuning |
The Following User Says Thank You to DeliciousTuning For This Useful Post: | diodelphi (01-28-2015) |
01-27-2015, 12:03 PM | #255 |
Drives: 13' BRZ
My FSI powered GTI ran closed loop all the time. Made tuning fairly simple and "safe" even at 500hp. Just turn the boost up, check timing pull and go... *i do not recommend this* :-)
Sent from HTC M8 while in burnout mode |
01-28-2015, 06:29 AM | #256 |
The Cloudmaker
Drives: GT86, G37S
Are you using an oem sensor for this, or 0-5v input from an external wideband controller ?
... my build thread: maxjedi's turbo "daily drifter" GT86 ... |
01-28-2015, 06:51 AM | #257 | |
Drives: 86
01-28-2015, 12:41 PM | #258 | |
The Following User Says Thank You to DeliciousTuning For This Useful Post: | SkAsphalt (01-29-2015) |
01-29-2015, 12:19 PM | #259 |
Drives: 2013 FRS
Need to def give @DeliciousTuning a shout!
Flash and go file is absolutely amazing! Car feels very smooth with his tune! Midrange, the car wakes up real quick even under no boost. Car idles like a champ and have no issues with the file what so ever. Most interesting thing is that I went from 12psi to 8psi WOT and have noticed quite the difference in a good way. Much smoother, pulls harder, constant pull even until red. I guess more boost isn't always the way to go! Thanks Bill! |
The Following 4 Users Say Thank You to ft86me For This Useful Post: |
01-30-2015, 11:33 AM | #260 | |
Very pleased to hear that you're enjoying your tune! Sincerely, Zach Delicious Tuning |
The Following User Says Thank You to DeliciousTuning For This Useful Post: | ft86me (01-30-2015) |
02-03-2015, 03:52 AM | #261 |
Drives: innovate sc frs
I have just purchased a Tomei EL header. Will I need an update? If so, is the car in any danger if I do take it out for a spin?
02-03-2015, 09:30 AM | #262 |
That Guy
Drives: 2013 asphalt FRS MT
The Following User Says Thank You to Calum For This Useful Post: | Jonesy86 (02-03-2015) |
02-03-2015, 10:19 AM | #263 | |
Drives: 2013 BRZ Premium Dark Gray Metallic
Sent from my SM-N900T using Tapatalk
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1 DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time) DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler |
The Following 2 Users Say Thank You to zoth For This Useful Post: | Jonesy86 (02-03-2015) |
02-03-2015, 11:50 AM | #264 | |
The Following User Says Thank You to DeliciousTuning For This Useful Post: | Jonesy86 (02-03-2015) |
02-03-2015, 01:56 PM | #265 |
210 intercooled, perrin 2.5 all the way back and stock airbox. (I also have the perrin cai, but have yet to put it on. Catch cans, cusco oil cooler. Advice? Should i pm you my dongle id so you can take a closer look? @Zach
02-03-2015, 02:12 PM | #266 | |
Similar Threads | ||||
P&L Oil Cooler for Forced Induction Applications!! Compatible with FMICs!!! | P&L Motorsports | Forced Induction | 9 | 03-26-2017 01:27 PM |
Most *fun* forced induction | bfrank1972 | Forced Induction | 45 | 12-22-2016 11:36 AM |
Infamous Performance is now offering dyno tunes by Delicious Tuning!!! | Infamous Performance | Announcements, Contests, Giveaways | 115 | 02-28-2014 12:38 PM |
February Sale. All Delicious Tuning e-tunes are 10% off!!! | Infamous Performance | Announcements, Contests, Giveaways | 19 | 02-28-2014 12:37 PM |
Infamous Performance is now offering dyno tunes by Delicious Tuning!!! | Infamous Performance | Forced Induction | 107 | 02-13-2014 11:36 AM |
