HKS Hipermax IV SP coilovers and height adjustment
Hey guys, I was wondering if anyone could chime in on an issue (or maybe it's not an issue at all) that I'm having with my HKS coilovers.
I lowered the back and the front coilovers about 40mm, which is about 1.5 / 1.6 inches. Of course I took into mind that, according to the HKS instruction manual, the coilovers come factory lowered by 19mm F and 21mm R. So I added on to that to make it about 40mm altogether. The car in reality actually sits about 10mm or so higher in the front than in the back (this was also the case with the HKS 'factory' setup that coilovers originally came with). Would it be correct for me to assume that the new coilovers need 'bedding' in, and that the front will eventually fall in line with the back? Any help / advice / tips would be greatly appreciated. Thanks for reading :w00t: |
FYI a drop on the threads of lets say ~40mm vs stock does not mean the car will sit 40mm lower (but it should be close). You should let the settle for a day (doubt it will make a difference provided they use quality springs) then go adjust them again to the height you want. Setting coilovers is a little trial and error. |
The thing that kinda blows is that the HKS manual states that the coilovers in the front can only be dropped to a max height of 42mm, but this still leaves a good 17mm of open thread to play with. Apparently going beyond this 17mm can cause damage to the coilovers. The back on the other hand can be slammed all the way down to 0. This means that the only viable option would be to raise the back to match the front, which is already at 40mm. I would rather lower the front by a smidge instead, but alas. Then you go to the HKS USA website, and they advertise that the exact same coilover drops to 61mm in the front. Go figure that one out :bonk: I may have to get in touch with HKS and see what they say. Anyway, thank you again. |
You mention the LCAs though. This would explain my problem. I put LCAs on right away, hence it's been lower in the back since day one. Thank you for sharing this detail with me, I very much appreciate it! :thumbup: :thumbsup: :w00t: |
"Paging Scott at HKS" "Paging Scott at HKS" "Scott please report to the Customer Service center"
:) pm sent |
@[YOYO] Just wondering, do you have creaking noise coming from the suspension when you go over speed bumps slowly? The noise will sound like an old spring bed.
@Bach415 I have had this same noise since they've been installed on the car since junish 2015. I've taken it to multiple shops to see if something's wrong with the suspension but everyone that looks and drives the car says it's working as it should.
Edit: Maybe @Torry@HKSUSA have an idea or can chime in? |
The fronts are the ones making the sound for me as well @Bach415!
| All times are GMT -4. The time now is 12:08 PM. |
User Alert System provided by
