Oil pressure/temp gauges & block8head.com gauge pod
Looking at getting dedicated oil pressure and temp gauges and already have p3. Would like to free up obd2 (disconnect p3) so I can log with my MX wifi odb2 while on track.
Not sure if the block8head.com pod (ideal placement for me) is sturdy enough for track, especially the dual pod. Alternatively I could put a single oil pressure gauge on top and oil temp in vent instead of p3. Your experience with the dual block8head gauge pod on track/ax? Thx |
Also, did anyone install new sensors for both oil pressure and oil temperature? I saw posts on the oil pressure sensor but still searching for the best oil temp sensor location. I know I can read oil temp via odb2 but would like to free it up.
im using their single vent pod since im using the ATI vent pod its nicely built using OEM vent
they do sell dual monitor gauges which im using
Thanks, did you have a chance to compare oil temp readings from the new oil temp sensor you installed in the oil pressure warning sensor location to the oil temps from stock sensor, accessible thru odb2? |
I've been introduced to Stack gauges and like their flash-beyond-threshold design. Gauge model: http://www.summitracing.com/parts/sgg-st3502/overview/
Could 120-130psi cold start pressures damage this 100psi max gauge in any way? I assume not but please chime in. |
Aftermarket gauges for the twins
I asked about these on the STX thread but have no response yet. I am wondering if anyone has tried the Longacre stepper motor gauges in a twin?
Ok, ordered Stack 3502 gauge and single vent gauge pod from block8head.com. Will be installed by EFI Logics by mid-April. Was considering both oil pressure/temp gauges but pressure is key and I can glance at the p3 gauge only when I see that the pressure gauge is flashing...less things to be distracted by in the direct field of vision. Thanks for responses
Post them up when you get them installed
2 Attachment(s)
Top left is Stack pressure 0-100 PSI gauge, bottom left is P3 (I keep it on oil temp) and the right gauge is AFR/boost. I'll take better pictures when I have some time. |
2 Attachment(s)
Better pictures
Danko - how solid is the mounting of the blockhead part? Thinking about the 2 or 3 pod model. Going to run DEFI gauges.
| All times are GMT -4. The time now is 05:23 AM. |
User Alert System provided by
