-   Issues | Warranty | Recalls / TSB (https://www.ft86club.com/forums/forumdisplay.php?f=72)
-   -   Horrible sound while decreasing speed in gear (no clutch) (https://www.ft86club.com/forums/showthread.php?t=109659)
bshep 08-16-2016 02:12 PM
My husband and I just bought a 2013 frs 2 weeks ago from a car lot. It drove like a gem when we first got it all the way up until 2 days ago when this horrible noise started. The noise is coming from somewhere under the car (can't really distinguish if it's from the dif or the trans). While driving above 20mph and letting off the accelerator the noise starts. Ithe sounds like something is loose, shaking, and grinding. If I push the clutch in or take it out of gear the noise starts. When it first started 2 days ago it wasn't very loud now it is horrifically loud and driving my husband crazy! I have gone through a bunch of the forums whIle waiting for permission to post on here and I've seen a few threads but no real answers. Anyone ever experienced this or have any ideas to point me in the right direction. Oh the car has 30000 miles mostly stock besides exhaust, coil overs, light weight pulleys, and a cold air intake. To my knowledge thats everything. Help please!
guybo 08-16-2016 02:15 PM
Post a video
asdf 08-16-2016 02:18 PM
go to the dealership-should still be under warranty?
bshep 08-16-2016 02:22 PM
They called me and said they could look at it today, but would have to go from there. I'll try to take a video on the way!
Sent from my SAMSUNG-SM-N920A using Tapatalk
asdf 08-16-2016 02:24 PM
best of luck to you! curious to see what they say
bshep 08-16-2016 02:25 PM
Thanks me too. Hoping for a loose bolt that I couldn't see!!! A girl can wish.
Tcoat 08-16-2016 02:32 PM
Throw out bearing.
bshep 08-16-2016 02:33 PM
But it doesn't make any noise at all when the clutch is engaged. The way I understood a bad throw out bearing it would make the noise when the clutch was engaged not disengaged.
JazzleSAURUS 08-16-2016 02:54 PM
Opposite. :thumbsup:
I agree that I think it's a throw out bearing.
If the dealership will do it, I vote have them replace the whole clutch kit, including flywheel while they are in there. If you're taking it apart you may as well depending on condition. If they'll comp a part of an Exedy stage 1 kit, it's a nice unit and makes the pedal firmer.
bshep 08-16-2016 03:24 PM
Thanks waiting now for them to take it back to check!
guybo 08-16-2016 03:35 PM
If it is the TOB or some other part of the clutch, it makes me wonder what other mods were done to the car before it was traded in?
Did you see the carfax and maintenance records?
bshep 08-16-2016 03:36 PM
Yea it had nothing on the carfax. Now records that I Remember seeing.
number_Un0 08-16-2016 04:12 PM
my car is making the same noise, it started happening after my transmission was replaced under warranty for the 5th gear grind, I've been driving it like this for 8k miles now. (im at 32k). I've just been to lazy and didnt feel like putting my stock exhaust back on and take it to the dealer.
bshep 08-16-2016 05:00 PM
They said the entire rear end is gone, but they are going to fix it and cover everything besides a rental.
