Clutch Replaced
I had my clutch replaced today by Toyota and after I picked it up and drove it home I noticed a few things I wasn't used to. I'm not sure if what I am going to describe is normal operation after a clutch replacement or something I should be concerned about...
When I shift into different gears I can hear and feel the gears changing as I shift. Specifically, below my right forearm as I shift I kept feeling a faint noise like something was hitting the armrest underneath my arm. I had never felt or heard anything prior to the replacement and prior to repair it was smooth shifting through all gears. Do I need to allow the car to go through a break-in period? Also, as the car was idling the RPMS would bounce from the idle point of 600 RPMS then up to 7-800 RPMs and then dip down to 480 RPMS and back to 600 RPMS every 15 seconds or so - the AC was on. When I have the AC off it holds at 600 RPMS which is normal from previous operation. The RPM fluctuations would happen every now and again before when my AC was on, but it has me concerned as I just picked up the car up and I'm experiencing these different things. Should I give it a fee days for the car to adjust to the new clutch? I'm not tech savy enough to know if that has anything to do with it, but any feedback is appreciated. The car has about 53500 miles - 2013. Thanks. - Rob ********VIDEOS UPLOADED ONTO PAGE 3*********** |
When doing a clutch job they typically drain the trans fluid and refill it after. Changing it from factory fill changes the shift feel and gearbox sound, maybe because it's a bit slicker.
RPM fluctuations are normal even if A/C isn't on it will fluctuate if you roll both windows down for instance. |
Why do you figure your old clutch went out .. ?? Boosted, tracked, new driver, don't know ....?? humfrz |
humfrz |
One of the throwout bearings went and it happened to be covered under warranty. They said it wouldn't be a bad idea to just replace the entire clutch since everything has to come out just to replace the bearings. I said why not and all I paid for was parts instead of getting charged $1500 with labor all I paid was $587 including tax.
They screech when they start seizing. Don't wait that long. |
I didn't realize the tail shaft had to come out of the transmission on the FR-S. I'm stuck in the 50's again ...... :sigh: We used to take apart the universal joint and then drop the driveshaft. Or, at least I did ...... yep, those "C" clips were a butch to get off of the universal joint without messing them up ..... :mad0259: Thanks again fer the edumacation. I'm going to add you to my consulting staff, along with @Ultramaroon. humfrz |
Stock lube does a better job of hiding it at the expense of being tougher to shift when cold. |
| All times are GMT -4. The time now is 08:15 AM. |
User Alert System provided by
