-   Software Tuning (https://www.ft86club.com/forums/forumdisplay.php?f=88)
-   -   OFT Launch Control/Anti-Lag - spit flames? (https://www.ft86club.com/forums/showthread.php?t=113373)
H-TownBrz 11-30-2016 01:35 AM
I'm very new to the tuning scene, and I was just wondering if there was a way to implement a spark cut at the launch control rpm limiter so it can shoot flames... Sort of like the megasquirt miatas and their spark cut to induce flames on their launch control. Any input will help!
Leonardo 11-30-2016 02:34 AM
I remember a thread... yep.
http://www.ft86club.com/forums/showthread.php?t=38795
aagun 11-30-2016 02:43 AM
u can do that using timing tables in romraider
if u set LC At 5k
go to the timing in gear blow the speed . then edit the rpm up to 6k . including 5k rpm
then if ur in gear blow the speed (2)mile stock rom . the retreat to -20
u can increase fuel target at 4k-6k in CL and OL at low load
wparsons 12-02-2016 12:17 AM
Unless you're catless, you're going to have a bad time with trying to shoot flames.
BRZyJ 12-02-2016 02:35 AM
:thumbsup:
Bisofication 05-12-2018 03:13 AM
if u set LC At 5k
@aagun Can you please explain more? I'm kinda a newbie and would love to do it (I got the oft with pop tune but would like to also have it when I LC)
Thanks
aagun 05-15-2018 04:06 PM
Thanks
I HAD LONG TIME NOT MISS WITH THAT THING
YOU NEED TO REMOVE IDLE CHECK FROM THE ROM
FRSBRZGT86FAN 05-23-2018 04:09 AM
Also it'll totally destroy any muffler packing and make your car louder in the long run.
Tor 05-23-2018 12:01 PM
Originally Posted by H-TownBrz (Post 2806000)
....I was just wondering if there was a way to implement a spark cut...
No, it's not possible with the stock ECU. To answer your actual question...
FRSBRZGT86FAN 05-26-2018 02:14 AM
Seriously? I could've sworn its possible somewhere in rom raiders tables, there's a fuel cut easily enough...
