-   Issues | Warranty | Recalls / TSB (https://www.ft86club.com/forums/forumdisplay.php?f=72)
-   -   Hissing clutch noise (https://www.ft86club.com/forums/showthread.php?t=113891)
FR-Sky 12-19-2016 07:50 PM
Hi,
When I cold start my car this morning, my clutch is making a hissing sound when I press and release, and it is gone after the car is warm up.
Is it a problem i should concern or it is normal because of the cold weather?
Thanks
humfrz 12-19-2016 07:56 PM
Oh, maybe the clutch parts (TOB) and transmission are just getting warmed up.
I wouldn't worry about it unless it gets worse.
humfrz
Ultramaroon 12-19-2016 07:59 PM
Can you make a recording?
Does it hiss when your foot is off of the clutch, or when you are pressing it?
FR-Sky 12-19-2016 08:35 PM
humfrz
Yea it just happened this morning between 1C-5C
FR-Sky 12-19-2016 08:36 PM
It only happen when press and depress, its gone when my foot completely off the pedal.
Also, its gone like 5-10mins after driving.
humfrz 12-19-2016 08:45 PM
Is it more like a "squeak" than a "hiss" ... ??
Squeak, like an old rusty spring ... ??
humfrz
FR-Sky 12-19-2016 08:48 PM
humfrz
I am pretty sure its hissing noise, its like air leaking sound.
Ultramaroon 12-19-2016 08:48 PM
Do you mean as you are moving the clutch pedal?
FR-Sky 12-19-2016 08:49 PM
Yes!
Ultramaroon 12-19-2016 08:53 PM
Originally Posted by FR-Sky (Post 2817557)
Yes!
Wow! Ok, I've never heard that.
Check your clutch fluid level in the reservoir. I can only make a crazy guess. that it might be air bubbles being forced through the small orifices in the master cylinder/clutch delay valve.
Hopefully someone else will recognize the symptom.
FR-Sky 12-19-2016 08:56 PM
What can I do at this point =[ ? I search alot on google and i cant find answer.
add fluid clutch? ignore it? normal in cold weather?
sad
humfrz 12-19-2016 09:15 PM
sad
Well, to follow up on what @Ultramaroon mentioned, first check the fluid level.
If it is up to the full mark, you may consider bleeding the clutch system to rid it of any air.
But, like I mentioned before .....I wouldn't go messing with it (other than bleeding the system) unless it gets worse.
humfrz
Ultramaroon 12-19-2016 10:26 PM
sad
Impossible to know. What color is your clutch fluid? Is it nice pretty yellow?
Like @humfrz said, if the reservoir is full just give it time to feel/listen for it to get worse.
Things to watch:
1. Extra pedal resistance. If it feels like it's binding then be careful to not break the clutch fork.
2. Trouble getting into gear. If the pedal feels mushy and you have trouble getting it into gear then there is air getting into the system. The only way that happens is by completely draining the fluid from the reservoir. Watch the level carefully.
Mr.ac 12-19-2016 10:33 PM
Mine is doing the same. Haven't though about old fluid. Might try a new stuff.
I was thinking it could be the TOB. But is been shifting fine since it began in the summer.
