engine misfires on rough road
Pardonez moi if this topic was brought up before--it didn't show up on a quick search. Many years ago (2013) my wife and I took my year-old FR-S on a road trip to Colorado. Somewhere in South Dakota there was a section of highway with pavement stripped down to a corrugated surface. I kept up with the traffic and the engine started running real rough. I took the next offramp and then the engine ran smooth again. I opened the hood and all the visible wire connections looked ok. I began worrying it was a gremlin Toyota and Subaru had overlooked. But when we got going again I kept the speed a bit lower, and I never had that problem again.
Just last week I read how some cars have a "rough road" sensor (not ours, I think). Apparently without this sensor, vibrations from a rough road can fool the knock sensor into causing engine misfires. If the problem doesn't persist, the misfire record gets erased from the onboard diagnostics. I don't know for sure this is what happened, but at least it sounds reasonable... |
Overpipe is slapping the engine and giving the knock sensor a run for its money? If you have ECUTEK, hook up your cable and look for knock correction when going off road again.
humfrz |
What makes you think that the engine was misfiring? Did you get a CEL for a misfire code? If so, which cylinder?
What did the car actually do whenyou drove down that road? |
Were you on cruise control or did you have your foot on the gas?
I hit a bump and got a coilpack CEL once, I think what happened is my body bounced over the bump causing me to lift off and get back on the throttle really quick, got some tip-in funkiness on the early '13 tune and CEL. Cleared it and it hasn't been back since even though I know the coilpack is bad, it only shows up under track conditions. |
I was probably jumping to a conclusion about misfires, but the engine was running very rough, meaning I needed more accelerator than normal to maintain speed. Because the road surface was a bunch of periodic bumps, the vibration was periodic and felt like the mechanical equivalent of a buzzing sound--very disturbing, I've never felt anything like it. The the vibration might have had a component related to the cylinder firing rate (= RPM/120, or around 20 Hz at 60 mph) or a harmonic. In these conditions is it possible the knock sensor was getting a signal that fooled the ECU into doing something to the engine timing? |
Yeah that sounds more likely. I don't think it was an engine misfire. Did you notice the brake pedal feeling any different?
Those sorts of bumps sound like they may cause wheel spin, I think Ultramaroon nailed it. |
Must've had your ESP cranked up to 10. :thanks: Anyhoo, check out @soulreapersteve's first clip. It's kicking in like crazy. Does that sound familiar? http://www.ft86club.com/forums/showp...postcount=9277 |
| All times are GMT -4. The time now is 08:32 AM. |
User Alert System provided by
