-   Issues | Warranty | Recalls / TSB (https://www.ft86club.com/forums/forumdisplay.php?f=72)
-   -   Car Driving Rough (misfiring) (https://www.ft86club.com/forums/showthread.php?t=120800)
Sojhinn 07-29-2017 07:25 PM
Need help guys.
I was driving for about two hours today all highway. Got off the freeway and about 1/2 mile down at a stop light the car starts shaking pretty badly.
CEL comes on when I pull away and I pull over.
Code p0303. Misfiring cylinder 3.
Thinking my car finally ate it's first coil pack. I swapped it out and I'm still having the same issue.
No codes have come up after restarting the car.
Mods:
Phantom ESC
JDL Header
Oft Flex Fuel
On about an E65 mix right now.
Any thing I should try? Any where I should take it?
At my parents house in Fontana, CA. I can tow up to 100 miles. WORST ISSUE: I'm moving to WA in two weeks. This needs to be fixed ASAP.
steve99 07-29-2017 07:33 PM
Hopefully you changed correct coil pack
I think misfire CEL is cumulative so it may need to get certain number of misfires over a period of time, so cel may take a while to show up again.
Think oft can log individual cylinder misfires real time
also check afr , LTFT and knock
Sojhinn 07-29-2017 08:17 PM
Just got p0201
Sojhinn 07-29-2017 08:18 PM
Also no misfires on oft.... Just really bad rough run.
Sojhinn 07-29-2017 08:30 PM
Now car won't start at all. It runs for a Sec and shuts off.
steve99 07-29-2017 09:56 PM
Check injector wiring.
check DI computer is securely grounded to chassis via all mounting screws
Car starts on port injection only
does it crank ?
is key symbol on dash green
run for 5 sec happens with key start models if theirs problem with security.
try different key if you have one
Weird you getting different symptoms, sounds suspect, might be electrical issue low batt volts bad earth or similar
Sojhinn 07-29-2017 10:02 PM
does it crank ?
Stupid question where is the di computer.
It cranks for a second , starts and shuts off immediately. Symbol is green.
steve99 07-29-2017 10:04 PM
black box under bonnet left side at top bolted to engine looks like an ECU
steve99 07-29-2017 10:05 PM
Also might be loosing fuel pressure if it starts runs then dies
car only logs high pressure fuel pump.
maybe look at AFR and see if it leans out then stalls
Sojhinn 07-29-2017 10:13 PM
does it crank ?
Figured out di computer wasn't grounded... Because I was checking injectors
It starts but running rough still at idle. Weird thing when I push on the accelerator it get better and doesn't seem to be an issue. Just under idle.
Also I have a solid check engine light but no codes....
steve99 07-29-2017 10:17 PM
non grounded DI computer produces all sorts of weird issues.
OFT only reads engine ECU codes, if code is generated by other computer ie auto trans or VSC oft wont read or clear it.
If you have another code scanner or android torque app use that.
you can clear all codes by removing battery for a minute.
remember to let car idle for a minute after reset or cams wont operate
ecu also get reset when you clear codes so rough idle might go away after a few minutes
Sojhinn 07-29-2017 10:17 PM
Also ltft is 0%
steve99 07-29-2017 10:22 PM
Originally Posted by Sojhinn (Post 2953940)
Also ltft is 0%
shiv might disable ltft in flex tunes not sure.
check the afr at idle should be close to 14.7
look at the short term fuel trim see if it large value and consistently positive or negitive
Sojhinn 07-29-2017 10:28 PM
-3.12 for stft
