-   -   hub centric ring help (https://www.ft86club.com/forums/showthread.php?t=126623)
Elliotw 04-03-2018 12:50 AM
So I picked up some hub centric rings for my TC105N
56.1mm to 73.1mm They dont seem to fit quite right. But I've never installed hub centric rings. I feel like the rings should go into the wheel more then this:
https://i.imgur.com/BdEKAIO.jpg
Top down photo:
https://i.imgur.com/ddhpV5S.jpg
What do you guys think?
Brzerker 04-03-2018 02:06 AM
Some hub centric rings are a tight fit, making sure it stays on. You could use a mallet and tap it slightly until it sits flush in the bore.
I've had some which are a loose fit which falls off as soon as u take the wheels off.
Spuds 04-03-2018 02:10 AM
Top down photo:
Well, if the backside of the wheel does not contact the rotor when installed, then it's not going to work.
Google came up with this among other things.
[ame]https://m.youtube.com/watch?v=j0fWPPNaeM8[/ame]
Also, it might be the picture but that flange looks a bit too big for the countersink.
Apoc 04-03-2018 09:48 AM
The problem is that you have the wrong size hubcentric ring. TC105N in 5x100 have a inner diameter of 65mm. Try rings with 56.1x65
http://nebula.wsimg.com/e9d732f621d5...&alloworigin=1
SCQTT 04-03-2018 10:56 AM
What if you need to go the other way? Can the center bore be accurately increased? My winter wheel/tire set up for my 2015 Corolla has a 54.1 center bore, so close to fitting on my 86 with a 56.1 mm bore.
Apoc 04-03-2018 12:01 PM
It isn't a matter of accuracy it may weaken the wheel.
SCQTT 04-03-2018 12:25 PM
Yeah, I could see that. I guess I just need to buy another setup or put the car away for winter. This was my first winter with the 86 and I didn't drive it.
Elliotw 04-03-2018 02:25 PM
This must be the problem. I will order the correct set.
