-   -   JDL 4-2-1 EL header (https://www.ft86club.com/forums/showthread.php?t=130248)
tehShirt 09-14-2018 09:12 AM
JDL 4-2-1 EL header
https://scontent-lax3-2.xx.fbcdn.net...51&oe=5C28001F
https://scontent-lax3-2.xx.fbcdn.net...6d&oe=5C30865D
https://scontent-lax3-2.xx.fbcdn.net...3c&oe=5C349D58https://www.ft86club.com/forums/[img...om/WLpbdgA.png
https://i.imgur.com/WLpbdgA.png
Got an email from JDL today. Exciting stuff!
I'll be testing a slightly smaller diameter primary version of the header very soon here that I expect to make more torque. This will likely be the production version of the header. The header uses 15 degree merge collectors and will feature all stainless steel flanges. Retail price will be $1099. If there was enough interest I could see about some sort of group buy pricing.
https://www.instagram.com/p/Bl_v97Kj...on_share_sheet
https://www.instagram.com/p/BmtLZSAH...on_share_sheet
@JDLAutoDesign any more info on this?
J1Avs 09-14-2018 09:55 AM
Woah! @JDLAutoDesign are you trying to take on the ACE350???
Interested to hear more!
Breadman 09-14-2018 10:55 AM
whats the price and does it still use stock OP?
gpvecchi 09-14-2018 05:09 PM
If it's cheap, it's mine.
Chuckls 09-14-2018 05:41 PM
It's available for purchase. You just need to contact JDL directly.
J1Avs 09-14-2018 06:28 PM
Any idea on price?
PulsarBeeerz 09-15-2018 02:26 AM
JDL doesn't do cheap...
gpvecchi 09-15-2018 06:12 AM
But cheaper than ACE...
Yoshoobaroo 09-15-2018 09:30 AM
That's not hard. Even if it's $500 more than the UEL it'll be cheaper than ACE.
On a side note, I'd like to see numbers where the car is tuned for each header. If this was on a stock tune for both the UEL would have been at a disadvantage and the difference might actually not be as large.
Lantanafrs2 09-15-2018 11:34 AM
It says tuned above dyno graph
Trust86 09-15-2018 12:48 PM
I don’t think it will be priced that much higher over the UEL bc of the slip joint connections.
gtengr 09-15-2018 01:17 PM
Visually the early merge of the second collector location makes me think it would more closely compete with the Ace A150. The JDL probably needs an overpipe and the Ace includes one so that should be factored into the cost.
jflogerzi 09-17-2018 12:48 AM
I am excited for this. I would love to compare this with my tomie uel
Breadman 09-17-2018 08:56 AM
Everyone forgets this when complaining about it burnt expensive. Price still.stung but it helps a little bit
