-   Issues | Warranty | Recalls / TSB (https://www.ft86club.com/forums/forumdisplay.php?f=72)
-   -   Bumper countermeasure SB18-200E - SUBARU RECOGNIZES (https://www.ft86club.com/forums/showthread.php?t=132308)
Trap63 01-08-2019 11:26 AM
6 Attachment(s)
..and after 5 years Subaru recognizes damned front bumper issue ABOUT gap!
JAPAN PRICE IS JPY 546 EACH - USD 5.10 - EUR 4,37 (see invoice)
[emoji106]Buy 57722CA030 PLATE BMPR SD
xjohnx 01-08-2019 12:25 PM
any idea when the part will be available to order? 57722CA030
8RZ 01-08-2019 12:27 PM
Isn't there already an aftermarket company that sells these?
Gunman 01-08-2019 01:02 PM
Part looks a bit different.
Trap63 01-09-2019 08:31 AM
sent a WA message to JP Carparts in Japan to request availability and $ in Japan.
nikitopo 01-09-2019 09:49 AM
The aftermaket company stopped selling their own part and now they are selling a revision which is much more difficult to install.
Subaru's part looks much better. :thumbsup:
sato 01-09-2019 10:35 AM
Subaru's part looks much better. [emoji106]
Yup, there is another thread on that part but don't have the link right now. Problem with the Subaru part is zero availability ATM.
Sent from my Pixel 2 using Tapatalk
Grady 01-09-2019 11:23 AM
This SB was issued in December. Just wait a couple months those parts will be in stock at every dealer. Parts are almost never available at the release of a SB.
Eazy-V 01-10-2019 07:38 AM
I assume this would also work on the FRS?
mswbrz 01-10-2019 03:19 PM
With this being a service bulletin and my car needing the recall should I just ask to fix during the recall ?
Grady 01-10-2019 06:16 PM
I do not recall?
maslin 01-10-2019 07:21 PM
Generally, a Bulletin is an update or guidance for a known issue, updated part, updated procedure, etc. It does not extend any additional warranty on top of your normal warranty.
A recall would be work performed under warranty regardless of the vehicles age or mileage.
A car may have 2 or 3 recalls, there are hundreds of bulletins that could apply to the same car.
Trap63 01-11-2019 05:07 AM
updated post #1 about Japan price.
ZionsWrath 01-11-2019 06:56 AM
This would be a bumper to bumper (no pun) issue. If you are not under the 3/36 you will be out of luck. If you have an extended warranty you might get it fixed depending on your contract.
Service bulletins are not recalls. Generally the way it works is you complain about issue and they will verify the issue and refer to service bulletin for repair procedure. If you go in and say hey there is a service bulletin I want this, they won't do it. We are lucky we have the internet and easy access to service bulletins because in my experience dealers are very secretive about them for some reason.
