-   Software Tuning (https://www.ft86club.com/forums/forumdisplay.php?f=88)
-   -   OFT v4 stg1 help (https://www.ft86club.com/forums/showthread.php?t=141749)
Daily86 08-03-2020 10:54 AM
OFT v4 stg1 help
2017 86 auto stock. Purchased a second hand ver2 OFT. Plugged it in the OBD2 port. Downloaded the stock tune to the OFT. Took the OFT to the computer and plugged in, did the updates. The tunes on the OFT were v3 tunes. I loaded the stg1 tune and tried it out. Not bad. Seemed a little better than stock. I knew that v4 were the latest. Downloaded v4 tunes from Open Flash website. Loaded the stg2+E85 tune to the OFT. Filled up with E85, drove until the LTFT were showing 10, flashed the ECU, everything was good. After some time noticed a few things to tweak with RomRaider. Fuel usage, Wayno AT/E85, soft rev limit, maf correction after start. Ran E85 for about 2 months:thumbup:, until I went to fill up one day and the stations E85 pumps were not working. Had to go back to gasoline, 93 octane. So I fashed the v4 stg1 tune. Ran this tune for about a 300+ miles. Not happy:thumbdown:. From 4500rpm and up it's great. But below that hesitation and bogs. Did some logs. Looked athem on Datazap. Did some reading on this site. Couldn't figure out what's not right. I decided to flash back to the stock tune. Wow, the stock tune isn't so bad after dealing with that stg1 tune. Not as stong at the top, but smooth on the way up. I will be flashing back to the E85 tune, but I would like to have a good petrol tune in case I need it. So, how can I get a copy of the v3 tunes? From what I've read, they were just beta v4 tunes. I would like to be able to open the v3 tunes in RomRaider also. How can I look at the stock tune in RomRaider? I assume I need a definition file for the stock tune. Is there something I can tweak in the v4 stg1 tune? Any help from you fine people would be greatly appreciated.
gt7877 08-04-2020 05:30 AM
https://www.ft86club.com/forums/showthread.php?t=71157
Daily86 08-04-2020 10:32 AM
Thanks. I've already read that post and this one http://www.ft86club.com/forums/showthread.php?t=94822. How can I look at the stock tune in RomRaider? I have not found that any where. How can I get a copy of the v3 tunes?
gt7877 08-04-2020 01:04 PM
U can find stock tube at Steve threat attachment
And first of all did u flash this actual CID for your ecu??
If u can post your cid I'll try to help u with definition
Daily86 08-04-2020 07:52 PM
Sorry, I don't know what you are trying to ask or tell me.
I've looked at Steve's thread and couldn't find a file for 2017 USDM auto.
The files I have are the ones I've downloaded from the open flash site.
(.bin & .xml)
The other file I have is the Toyota stock tune from the ecu. (.ori)
Sent from my SM-G930V using Tapatalk
gt7877 08-04-2020 07:57 PM
What is your CID???
IF U HAVE OFT CHK WHAT IS YOUR ROM ID
its not good to donwlod incompatible ROM I'd to your ecu
Daily86 08-04-2020 07:59 PM
The cal ID matched ZA1JK00D
Daily86 10-16-2020 10:28 AM
Resurrecting my old post. I'm asking if there is a way to download the files that are greyed out? If not, does someone have a copy they can send me?
elBarto 10-17-2020 06:45 PM
AFAIK it's not possible to download those. They are auto generated.
But you are lucky, I have a copy for K00D (don't know how I got it), those tunes were send out to beta testers and were never available for download.
V3 K00D
But use the v4 instead, those are better.
V4 K00D
Sam86 10-17-2020 09:21 PM
V3 K00D
V4 K00D
Are all non- A01I oft roms hacked to appear as that? The reason I ask is on my OFT tablet in tunes- info my CAL is A01I, but when I plug in my OFT and check in manager on the computer my cal is F20Q, and so are all the tune files (stage 1, 2 etc).
Does that mean my cal is F20Q but they're all hacked to appear as A01I so that they can be ran? Just confused as I thought my oft and ofm calibrations were meant to be the same
elBarto 10-18-2020 12:46 PM
Basically yes.
2012 - 2016 MT = A01G
2012 - 2016 AT = A01I
2017 - 202x MT = K00G
2017 - 202x AT = K00I
