-   GR86 General Topics (2nd Gen 2022+ Toyota 86) (https://www.ft86club.com/forums/forumdisplay.php?f=97)
-   -   60 MPH in 2nd (https://www.ft86club.com/forums/showthread.php?t=146750)
Panda Grahams 09-02-2021 02:37 PM
60 MPH in 2nd
I thought it might be interesting to note that the GR 86 will hit 60mph in 2nd gear, as seen in TheTopher's POV test drive. I think every video I've seen of attempted drag races and 0-60 tests have shifted to 3rd just before hitting 60. Do we think hitting 60 in second will reduce the claimed 0-60 times by Toyota and journalists?
Attachment 204904
series.trackday 09-02-2021 02:38 PM
Of course it will. That's why you CAN hit 60 in second.
bucketfoot 09-02-2021 02:44 PM
Yep, has absolutely nothing to do with the drivability of the car. This 100% for a completely useless (in the real world) lower 0-60 time.
Panda Grahams 09-02-2021 02:53 PM
Gotcha - and totally agree!
I am curious if Toyota's time had included hitting 60 in second, because it seems like they haven't. In C&D's test I think they hit around a 5.8(?), while Toyota claims 6.1. All-in-all it's too early and ultimately not important. I'm just very excited and trying to gain a sense of the car prematurely. Hitting redline is going to feel and sound great.
dowroa 09-02-2021 02:55 PM
Useful to know the end gearing with the stock tire circumference and if that changes per gear.
For autoX, it baselines and tire size changes you need to make for course setup.
Since this is a car that was primarily designed for work such as this, that is important.
From what I can see in first and second (I haven't found all the ratios anywhere yet), it doesn't look like an appreciable change.
Interested to see if these cars make it into an SCC2 or something similar.
Vital 09-02-2021 02:58 PM
the AT in the current gen hit 60mph in 2nd gear
timurrrr 09-02-2021 03:00 PM
According to https://www.tremec.com/calculadora.php,
at 7500 rpms with 4.1 FD and tire height of 24.618" (215/45R17) and the 2.189 transmission ratio in 2nd gear, the car should reach 61.2.
The 215/40R18 are even slightly taller (24.772") and reach 61.59.
Both are less than 100 km/h (~62.1 mph).
timurrrr 09-02-2021 03:02 PM
LMGTFY
https://www.subaru.com/2022-brz
-> https://media.subaru.com/pressreleas...l-new-2022-brz
-> https://s3.amazonaws.com/subarumedia...ecs_-FINAL.pdf
timurrrr 09-02-2021 03:07 PM
What's interesting is that Jason Cammisa specifically says he tested and the car only reached 59 in 2nd...
https://www.instagram.com/p/CSsZdsBFLW-/
mazeroni 09-02-2021 03:10 PM
But that was with the Primacy tires that are 17" right? So the tire is less tall... if I'm understanding correctly.
timurrrr 09-02-2021 03:11 PM
See my calculations above, they were for 17's.
dowroa 09-02-2021 03:47 PM
I am assuming he uses GPS to calculate speed and not the speedo, hence the need for the shift in reality.
OkieSnuffBox 09-02-2021 03:59 PM
That's because in the real world it's not really practical to smack the rev limiter and then shift. That will cost more time then just going to 3rd.
FlyingJett 09-02-2021 04:23 PM
Originally Posted by Vital (Post 3462453)
the AT in the current gen hit 60 in 2nd gear
It hits 100km/h in the second gear
