Has anyone attempted to install the JDM LED accessory liner
I ordered this part from JapanParts:
https://www.japanparts.com/parts/detail/?id=62952 And the kit comes with these grey plugin tips that are apparently supposed to plug into a harness that either I could not find behind the bumper or the USDM car does not have. I can always just tap a fuse in the fuse box to get these working, but I dont know which size fuse these lights should use. Has anyone tried to install these yet, and know where they SHOULD plug in? They look and function similar to the 2017+ LED accessory light that went next to the fogs, so if anyone has installed those, your experience might help too. |
Those look nice, how functional are they? Would love some kind of aux fog light to help cut through foggy morning drives!
Figure anything out?
They’re not fog lights, they’re accent lighting. They look pretty but they won’t be useful in fog. |
4 Attachment(s)
Finally figured out the install. Easiest way was to tap the amber side marker harness which are very close to where the new accent light wiring sits inside the bumper. This also avoids long cable runs to tap the fuse box and needing to remove the bumper. I cut off the terminals the accessory lights came with, then attached male quick disconnect terminals to the ends. On the side marker harness I spliced in female terminals to each line, so the accessory lights can be easily disconnected if you need to remove the bumper. Basically, connect the side marker and accessory lights in parallel. When finished I wrapped the whole thing in electrical tape and heatshrink for water proofing and zip tied it out of the way. This install could be easily done with t taps too. Just in case, I measured with multimeter, and it shows total draw is way less than the 10 amp limit on that circuit.
Driver side: -Red side marker wire to white accent light wire. -Black side marker wire to black accent light wire. Passenger side: -Pink side marker wire to white accent light wire. -Black side marker wire to black accent light wire. |
Looks absolutely sick, and thank you for the write up. Now begins the internal decision of whether or not I’m capable of doing all that.
Does the LED accessory sit on top of the pre-exiting vent there, or did you have to do some work to remove the front and pop it out? Haven’t been able to find any information on this, you’re definitely the first person to do it! |
Really want a set of these but dont feel like paying $400 in shipping from Japan to the US
Looks great! Although I hate the idea of cutting into the wiring harness of a brand new car, as a minor as it might be.
Maybe they will see the demand and add it as an option for the '23 models. |
You could make a set of patch harnesses. |
| All times are GMT -4. The time now is 07:11 AM. |
User Alert System provided by
