-   Suspension | Chassis | Brakes -- Sponsored by 949 Racing (https://www.ft86club.com/forums/forumdisplay.php?f=59)
-   -   Best option for a slight drop (https://www.ft86club.com/forums/showthread.php?t=150026)
Sam86 06-06-2022 08:44 AM
Do I just save for coils or can I get away with STI/ Tein springs?
I have the Aero bodykit with a front splitter and am currently 11.5mm from the ground on stock ride height with 18” wheels on 235 tyres. I have an angled driveway and would scrape on an angle every day when I was on my 17” wheels so I believe anything over 15mm will be too low for me.
I daily drive, my commute is fairly bumpy in one area (not an issue on my current height but I had to be careful when I was on the smaller wheels). It’s hard for me to justify the cost of coils unless it’s REALLY worth it as I don’t care to mess around with camber. I just want to close the fender gap slightly and retain a similar ride quality
Any recommendations on what I do?
Sam86 06-06-2022 08:57 AM
I have the Aero bodykit with a front splitter and am currently 11.5mm from the ground on stock ride height with 18” wheels on 235 tyres. I have an angled driveway and would scrape on an angle every day when I was on my 17” wheels so I believe a drop greater than 15mm will be too low for me.
smg1138 06-06-2022 12:28 PM
Racecomp Engineering Yellows would be a good option but they're a 20mm drop. I'm not aware of any springs that offer less of a drop than that. Maybe coilovers set really high would work if cost isn't an issue.
norcalpb 06-06-2022 01:10 PM
STi and RSR Down are both 5-10mm drops while being stiffer.
RSR SUPER Down takes you lower than an inch I believe.
Sam86 06-06-2022 10:28 PM
I’ve seen good things about RCE’s but I think 20 will be too much. The aero front lip alone visually lowers the car about 20-25mm from stock and I have a splitter in addition to that.
I know JDM sti springs and Tein are 15mm I just haven’t heard much about how they handle on stock struts or whether there’s a better alternative.
At this stage I would say I’m on a budget. It’s hard for me to justify paying 4x the cost of most springs when I wouldn’t really be utilising everything coils offer aside from ride height
Wally86 06-07-2022 07:47 AM
If you're not looking for aggressively spec'd wheels, springs and struts work fine for cheap (especially if you're installing them yourself). Some specs require coilovers to fit.
I commute in my 86 on Tein Flex Zs and haven't had any harsh ride issues BUT I only dropped the car an inch.
blsfrs 06-07-2022 01:43 PM
I just installed Tein Flex A and lowered about an 1". Similar report as @Wally86 as to ride quality.
gen3v8 06-07-2022 05:21 PM
11.5mm. I`m sure it`s 11.5cm;) 100mm is legal minimum up here. i`m on MCA coils and lowered about 30mm. Sure i still have 110mm+ to the lip. I can check when the sun comes up. I`ll give you the wheel center to wheel arch measurement(355mm F 350mm R measured at the top center)
Sam86 06-07-2022 11:38 PM
Thanks,
Yea the body kit visually lowers the car a lot. The 11.5 measurement was from the front of my splitter, if I go off the side of my splitter it’s 10.5mm. This is my ride height after installing larger wheels. On 17” wheels I would scrape leaving my driveway and entering work on a daily basis. That’s why I’m hesitant to go beyond 15mm
All my suspension components are completely stock
https://i.ibb.co/7Y2N5Fp/A4-B698-EF-...-C75011-DC.jpg
https://i.ibb.co/31X8qcd/AE958-F2-B-...89-E98-D79.jpg
Height on 17” wheels (about 5mm lower than what the 18” raises me by) still stock suspension with 225/45 tyres. This height was fine for 90% of my daily driving but there were the occasional steep ramps/ dips I would scrape.
1inch drop from where I’m at would put me around 20mm lower than this picture which I think will just be that little bit too low for the repetitive scraping to start causing damage to my bumper over time
https://i.ibb.co/hYxKJ5v/3-D522-F95-...A76-F822-B.jpg
EAGLE5 06-08-2022 01:30 AM
Drive more aggressively and wear your tread off. Replace the tires with smaller OD tires.
gen3v8 06-08-2022 01:41 AM
2 Attachment(s)
My Lip is 120mm 10.2cm clearence and the car is low enough on 18" x 9" rims with 255 35 18 Zestino Gredge 07rs
Sam86 06-09-2022 01:58 AM
Do the MY17+ BRZ’s sit higher than the 13+ 86’s from factory?
I’m visually at the same height as you with no suspension mods, just my front lip and splitter….
https://i.ibb.co/XL7Gb74/3717-D0-F0-...E727-BB323.jpg
gen3v8 06-09-2022 05:42 AM
Mines a Ts its factory lowered on the sti springs and sachs shocks to start with. I am now on Mca coilovers lowered 30-35mm. Measure upwards from the wheel center to guards lip. Mine is 355mmFront and 350mm rear. So mine may have a different rake angle. Mine is all recommended settings by Gazoo racing car suspension builders MCA (Mike Cootes Australia). And it handles f**king perfect street or track with some simple turns of a dial.
Espi 06-09-2022 07:40 AM
From what I've seen for minimal drop, I'd say best bet is JDM STI springs or RSR Downs (very mild 15mm drop), followed by Racecomp Springs (mild 20mm drop).
