-   -   Recaro Pole Position side mounts (https://www.ft86club.com/forums/showthread.php?t=152158)
gpvecchi 12-30-2022 04:55 PM
I fitted a Recaro Pole Position ABE with its specific ABE brackets, but it sits quite high.
Do you know if the FIA side mounts can be fitted on the ABE model?
They should be lower.
Or, can you recommend another specific side mount?
Thanks!
Ruben_86_ 02-08-2023 05:24 PM
Thanks!
I am in the process of manufacturing and selling some side supports for recaro pole position abe using the oem sliding guides
https://i.imgur.com/PtGzeNP.jpg
https://i.imgur.com/E5En7z1.jpg
You can talk to me on Instagram if you're interested, I should have them ready for production in few weeks
@Ruben_86_
gpvecchi 02-09-2023 02:07 AM
Thank you very much, but I have the JDM specific Recaro sliders. Do you plan to make a standard, but lower side brackets too?
Ruben_86_ 02-09-2023 03:33 AM
no, I like to use the original sliders, they work much better than the recaro or any aftermarket brand.
over time they get loose and make noise, while the oem ones are much more rigid and slide smoother
Mike_ZN6 02-09-2023 11:50 AM
@Ruben_86_
@Ruben_86_ those look awesome! Is that your interior? I want that same setup with dual Recaro Pole Positions. Do you have any more pics? I don't have instagram (I searched for you and it says your account is private).
Ruben_86_ 02-09-2023 02:25 PM
yes, it's my car, I don't have many photos of the interior
https://i.imgur.com/aWSIlN5.jpg
https://i.imgur.com/yS1yTe6.jpg
I am very happy with the seats, they are much more comfortable than they seem, everyone who travels with me tells me so.
gpvecchi 02-09-2023 04:48 PM
To use stock sliders, they need to be cut away from the seat, I'm not interested in damaging stock seat.
Sorry, but Recaro sliders are top notch, much better than stock ones and will not get play during time. They are made by Klippan, that's the stock producer for many german cars.
NoHaveMSG 02-09-2023 06:21 PM
No, they unbolt after you remove some plastic clips. No cutting.
Ruben_86_ 02-09-2023 07:27 PM
I also have the recaro and they do not have the quality of the originals.
Falkon240 02-10-2023 01:15 PM
Bride FG is low in these cars. The lowest setting is so low the bottom of my bucket seat was sitting on the floor.
You can see how much lower my driver seat is (side mount) bride FG seat rails versus my passenger (bottom mount) Bride MO
https://i.imgur.com/xFRNQOa.jpg
gpvecchi 02-10-2023 05:32 PM
Unluckily I don't thik that Bride FG sliders fits Pole Position, as the maximum width is 395mm, while the PP is 405. PP will hit the sliders, while typical japanese buckets fit between them, so they can go much lower.
Ruben_86_ 02-12-2023 07:29 AM
https://i.imgur.com/jm8WMsu.jpg
430mm
Mike_ZN6 03-04-2023 06:42 PM
@Ruben_86_ Were you able to install the driver/passenger Recaros and disable all the dash lights for the air bags, etc. ?
churchx 03-05-2023 08:41 PM
I wonder if such custom made side mount brackets:
1) don't net extra width due their shape like L, not 7, like in later schematic pics?
2) if they cannot be made adjustable for wider selection of seats .. by simply changing their bottom mount holes to longer slots?
