-   Suspension | Chassis | Brakes -- Sponsored by 949 Racing (https://www.ft86club.com/forums/forumdisplay.php?f=59)
-   -   '22+ brake pads same as '13-'20, right? (https://www.ft86club.com/forums/showthread.php?t=153470)
ZDan 06-01-2023 09:52 AM
Looks like gen2 brake pads are same as gen1, but double-checking!
My first track days with the '23 won't be this weekend, will drive a friend's '17 86 while '23 waits for new oil pickup tube screen...
dragoontwo 06-01-2023 11:11 AM
The pad shape and size is the same, but I think they may be a slightly different compound.
nomtimesthree 06-01-2023 02:37 PM
The EBC pads I’ve been running are listed as gen 1 non brembo application. Fit and works as it should. I believe the calipers are the same PNs as gen 1.
ZDan 06-01-2023 04:50 PM
Thanks guys, it finally occurred to me to check CSG part numbers for my pads (duh) and yeah, they are the same for '22+ and '13-'20 non-Brembo. Cool, I'm in bizniss...
CounterSpace Garage 06-03-2023 04:57 PM
Gen2 OEM calipers are the same as the Gen1 base calipers (not the Brembos). You'll definitely like the new Gen2!
ZDan 06-06-2023 11:25 AM
Ran pads I ordered for my '23 in my bud's '17 86. I would say "no problem" but somehow I knocked the friction material off the pad backing plate on one of the new pads! So I ran 3 new front pads with 1 old DTC60 pad with ~0.080" remaining for most of the weekend, being very easy on the brakes. Ran the old pad down to ~0.060" then swapped in another DTC60 at ~0.080" for last practice session and time trial with full max braking, no prob... Time-trialed in damp conditions, beating one rival in that run group, but main competition got to go out later in the dry, so I got P2, I'll take it!
