First 7 Must-Do Mods
Hey Twiners,
Here's my latest video where I share my recommended first seven mods to our BRZs and GR86s. The big point is not unplugging the fake engine noise as mod one...but it's certainly on the top seven list. Let me know what you all think and what your first seven mods were or are going to be! Cheers, Mike https://youtu.be/pcjQSowXLGU?si=vDOa5P8hpE6GOnlE |
Thanks for sharing
Why not just post the list of mods here, so we can discuss them? This is, after all, a forum.
Because that wouldn't drive views and clicks the their channel. But you already knew that.
"Twiners" Heehee
I mean, he also posted a link to a video about second-gen cars in the part of the forum for first-gen cars, so...
My first 5 must do mods under $250 that I would do basically on day 2:
1. performance alignment (add camber bolts or OEM crash bolt) 2. Cusco heel/toe pedal 3. MTEC shifter springs 4. rear subframe inserts 5. rear diff mount inserts (removed front bottom) Then next 5: 1. wheels and tires (properly sized and the right compound for your application) 2. suspension (properly selected for your application) with proper alignment 3. rear lower control arm 4. rear toe arm 5. MCA traction mod + rear trailing arm Something like that. A few other bits I really like, but those are the things I'd be prioritizing if another BRZ/GR86 fell into my lap tomorrow. - Andrew |
- Andrew |
Agree with you, next up would be performance alignment. I love the Pedders top hats. Just a little sprinkle to get it closer to neutral. |
Rear shifter bushing is also good Whiteline transmission bushing insert would be an immediate. STi/TRD engine/trans are good too, just expensive by comparison. Quote:
Also quite happy with pedders. The added caster added a bit of steering weight for me. Wheel wants to pull to center faster If that makes sense. |
- Andrew |
| All times are GMT -4. The time now is 09:22 AM. |
User Alert System provided by
