BRZ smart access customization (unlocking all doors)
If you have a BRZ with samrt access. you all know that the key only unlock the door that you are approaching (default setting). i have read throught the owners manual and it tell you to go to the dealer to perform custom setting to your desire. Well as being a tech at a lexus and seeing this car is mostly toyota influence including the smart access. I tried something with the remote to see if it works on a subaru smart access like it does with lexus. And yes it does work so i will pass it on to fellow BRZ with smart access so you dont have to drive to the dealer to get it done or be charge with it (lexus we do it for free the first time on all customization and will charge after, not sure how subaru does it.) To Unlock both doors when approaching the driver door. be inside the car key off (dont push the start button) hold lock and unlock button for at least 30 seconds and you will hear the door lock responding. once you hear that go outside lock the door and pull on the door handle to see if both doors unlock. There are a few settings but it should not take you more than twice to get the right set up. settings will eventaully cycle through if you do it a few times. It only took me 1 time to get the setting i want. Hope this helps
my setting is at both doors unlock when i approach either doors. |
That's awesome. Even though I will most likely be getting an FR-S, That is still great to know. Thanks
Hmm all I did was open the door and hold unlock for 10 seconds and it changed.
Is there any way to disable/enable the car beeping when doors lock/unlock?
Our AUDM cars don't beep and its pretty annoying |
I think the aussie dealers are either too lazy or incompetence.
i asked about having the interior light not turned on when you get close to the car but they said it can't be done although the manual clearly said it can. |
Or if you're the tech type, you can buy the USB cable on ebay and a lot of those will come with bootleg copies of techstream, so you can do it yourself. |
Do you know what other things you can configure with Techstream? I have a few things in mind that would be great!
EDIT: also where is the OBDII port on these cars? should be <2feet away from the steering wheel right? I'll have a crawl under soon... EDIT2: I found your thread . Thanks for the info there. I'll look into getting one and seeing what it can do. They are pretty cheap. |
thanks, was wondering about that
Just realised this whole thread is in the wrong section. But ah well...
Does anyone have anything like this but for the FR-S/BR-Z/86? http://www.tundrasolutions.com/forum...lectronics.pdf It's basically a list of allll the customisable electronics settings for the tundra, through techstream interface... |
To clarify this is all done (lock/unlock) with the remote?
| All times are GMT -4. The time now is 08:05 AM. |
User Alert System provided by
