-   -   A few night shots at the track... (https://www.ft86club.com/forums/showthread.php?t=41784)
CSG Mike 07-16-2013 04:41 PM
More pics coming soon at www.facebook.com/counterspacegarage
Brakes are AP Racing Sprint with Carbotech XP12 pads
~1700-1800F
https://sphotos-a.xx.fbcdn.net/hphot...4_472993_o.jpg
More evident gradient on the brakes here, showing how effectively and quickly the brakes dissipate heat!
https://fbcdn-sphotos-d-a.akamaihd.n...02048384_n.jpg
GTB/ZR-1 07-16-2013 09:34 PM
HOT stuff! lol
Needs some rear bias--almost looks like all front bite!
CSG Mike 07-17-2013 12:18 PM
Originally Posted by GTB/ZR-1 (Post 1074626)
HOT stuff! lol
It's hard to get the rear hot enough when all the weight is in the front!
It doesn't help that we're running the AP Racing sprint kit.
On a side note, bias doesn't REALLY matter if you're not using the pedal dance; EBD redistributes braking force anyways...
FRSBRZGT86FAN 07-17-2013 12:28 PM
Has anyone made a serious hardcore track only FRS/BRZ? If so I would love to see what someone would do with carbon-ceramic discs and pads.:confused0068:
CSG Mike 07-17-2013 12:41 PM
Those brakes would cost almost as much as the car!:eyebulge:
FRSBRZGT86FAN 07-17-2013 12:44 PM
Like I said hardcore :lol: , but I think with aftermarket disc rotors and pads, if it had some sort of cooling ducts they would be fine, at least enough to fend off some brake fade.
SnapOv3st3r 07-18-2013 12:44 PM
Well, there are Ohlins suspension for it that will run you $5k. That's pretty hardcore, so a matching braking system probably isn't that far off.
FRSBRZGT86FAN 07-18-2013 12:47 PM
Yea but you have to be hitting some pretty serious speeds to get the brakes to temp if they were carbon ceramic.
vividracing 07-18-2013 12:54 PM
I thought you had neons there for a second.
SnapOv3st3r 07-18-2013 12:54 PM
Most tracks in the States you don't have a long enough straight, but at my local track, the front straight I would clock 140+mph before having to brake into turn 1.
