-   Issues | Warranty | Recalls / TSB (https://www.ft86club.com/forums/forumdisplay.php?f=72)
-   -   coolant leak or burned rubber smell (https://www.ft86club.com/forums/showthread.php?t=59278)
Saf 02-26-2014 02:39 PM
Hi there,
2013 FR-S 15,000kms had already done the oil plate twice and also done passenger side valve cover sealant once.
In the same time frame since December 2013 experiencing odd smells, but what prevails is sweet taste in mouth right after sometimes 5mins up to 1 hour of driving. Have faint and thin oily film on windshield and side windows.
Been to couple of different dealers a few times to no fault found and kicked out every time.
Last night at -7C upped heater and car started to fog up with the halo around bright lights, even heater on full blast, it was getting worse and of course with sweet after taste in mouth. Any one experienced anything similar..
Any info or how to get Toyota to acknowledge its FUBAR and fix it once for all, would be fantastically appreciated !
SloS14 02-26-2014 02:45 PM
Are you by any chance eating candy?
Losing coolant?
Bad heater core?
Any dampness on floor?
White64Goat 02-26-2014 03:12 PM
Sounds like heater core has a leak........
Razz 02-26-2014 03:40 PM
Yep what he said.
Coolant leak at heater core.
Saf 02-26-2014 10:40 PM
Losing coolant?
Bad heater core?
- Coolant in minimum lever mark
- Toyota won't touch the car unless "obvious" causes appear.
(No visible leaks, no coolant smell, had already 3 techs in my car, NONE noticed anything !!!)
Saf 02-26-2014 10:41 PM
Originally Posted by Razz (Post 1558882)
Yep what he said.
that is what I am arguing, but if they don't see it, they will not touch it
Turbo95eg6 02-26-2014 11:17 PM
Your all wrong. It's probably just the heater core.
humfrz 02-27-2014 02:33 AM
You might try some "stop leak"; but if you do, make sure it's compatable with the "blue stuff" coolant.
humfrz
