-   -   Fuel pump running when the car is off? (https://www.ft86club.com/forums/showthread.php?t=61574)
Target70 03-24-2014 11:57 PM
I sit in my car to listen to the radio or read a book while I eat lunch, and on occasion I will hear humming from the dash, and other times I will hear humming from the trunk. I got out today slid under the back of the car and am pretty sure it is the fuel pump running, but the car is turned completely off. I don't even have the key in the ignition. It will run for over a minute, I don't know exactly how long it goes, because I usually get annoyed and I turn the key on to acc+, then back off to make it stop. All I can think is that it is keeping the fuel system pressurized. Anybody have any idea?
Turbo95eg6 03-24-2014 11:58 PM
Normal. Search or read the manual.
P@ul 03-25-2014 12:13 AM
It says on for a while, I've noticed just sitting in the car finishing a phone conversation with the car off. *shrugs* nothing wrong.
humfrz 03-25-2014 12:19 AM
It may be the purge pump you hear running (fuel evaporation leakage check).
Quite normal.
humfrz
Target70 03-25-2014 05:54 AM
searched before I posted, doesn't show anything related unless it's farther down the list then I looked. I read manual first day I bought the car, I never saw anything about the fuel pump running when the car is not in operation.
I never said it wasn't normal, Just not sure why it was doing it.
humfrz: It may be the purge pump you hear running (fuel evaporation leakage check).
I did not know there was a pump for that, but then again I am used to a carbon canister working off of vacuum lines and solenoids, and only working with the car running. I have no clue how this one is setup.
Thanks.
Shagaliscious 03-25-2014 06:37 AM
Thanks.
Straight from the manual.
Approximately five hours after the engine is turned off, you may hear sound
coming from under the vehicle for several minutes. This is the sound of a fuel
evaporation leakage check and, it does not indicate a malfunction.
cfordart 03-25-2014 02:51 PM
My car and my wife's Prius were both "talking" to each other in the garage the other night....
AznBRZer 03-25-2014 02:52 PM
I'm not sure if anyone's mentioned it yet, but it's the fuel evaporation leakage check. :D
5hairpins 03-25-2014 03:21 PM
Also for those of us who have the starting issue, turning on Accessory gets the pump primed and allows for first time starts. When I just turned the key all the way without waiting at ACC position for a few heartbeats, my car would not reliably start.
humfrz 03-25-2014 04:08 PM
.....a Prius plus a FR-S would produce a ____________(what)??
:popcorn:
humfrz
Target70 03-25-2014 04:20 PM
shagaliscious: Approximately five hours after the engine is turned off, you may hear sound coming from under the vehicle for several minutes. This is the sound of a fuel
I appreciate it, I'll have to read it again when I get home to see I can find it.
humfrz 03-25-2014 05:01 PM
It appears on page 14 of my FR-S manual..... ;)
humfrz
mav1178 03-25-2014 06:32 PM
http://techinfo.subaru.com/proxy/712...316DSTIS_2.pdf
Just go read the PDF version of the manual on Subaru.com... I'm sure there is the same thing on scion.com
-alex
