Bendpak QuickJack BL-5000
I purchased a Bendpak QuickJack BL-5000 last December and was able to use it for the first time yesterday to swap out my winter rims/tires for my summer set. Just a quick video that shows how it works in case anyone else was interested in it. I only raised it to the first level since I was only changing out rims/tires. It goes up one other level for a total height around 24". My car is lowered 1" and I was able to safely drive over the ramps and slide them out.
[ame="https://www.youtube.com/watch?v=2zjJKwSGuFc"]Bendpak Quickjack BL-5000 lifting Subaru BRZ - YouTube[/ame] |
I need that.
Where did you buy it? |
that's nice. how much did you pay for it? and is it safe to crawl under or do you still need jack stands?
apparently these things were plagued with problems of leaky quick couplings. Did yours have any leaking issues?
The BL-3500 (3500 lbs capacity) is only about $1k on ebay. Seems like a really useful tool that'll pay for itself with time. Tempted.
Jacking it up takes almost as long as whatever work I'm doing on it most of the time. |
I need this in my life.
Fluid changes, brake or suspension work, exhaust work and on and on.. All easier. |
How are the jacking points? Just on the pinch welds with the rubber blocks? No issues with the distance between blocks?
I bought the BL-5000 because it is a little bit longer. It still does not span the 60" that are between the front/rear jack points. It's reach is 53" and it comes with some 1.5" and 3" rubber blocks. I used the 1" blocks and put the front on the jack point. I had considered something like the Atlas Kwik-bay 7000, but that thing is like 900lbs and not easy to move around. Plus it would still not reach the 60" jack points. Overall, very happy with my purchase and it's made things so much easier and faster. |
Was that full lift?
| All times are GMT -4. The time now is 10:49 AM. |
User Alert System provided by
