AVO Turbo Kit Install
Hey guys,
This just an informal thread for those of you that are interested, documenting an AVO Turbo Kit install I am doing soon. The person opted for a "Package Kit" which comes with a Stage 1 Turbo kit, free-er flowing drop in panel filter, oil catch can, 3BAR MAP sensor and BOV. The order was shipped off last week Tuesday and arrived almost exactly a week later to my door. If all goes well, the car will be picked up this evening with a base (stock) dyno run being done tomorrow and work starting on the car this weekend. From there an oil change will be done and a tune developed and thoroughly tested and then its back to the dyno for another run. :burnrubber: The car is going to start its turbocharged life at between 0.4 and 0.48 bar boost and we will go from there. http://i57.tinypic.com/xe06fk.jpg http://i58.tinypic.com/etupf6.jpg Very well designed and thought out piece of kit! http://i61.tinypic.com/30lec0l.jpg http://i57.tinypic.com/2n9ays1.jpg http://i62.tinypic.com/vq14dd.jpg Have a great Thursday :party0030: |
That does look very neat... doing a full photos-of-install-and-all thing?
Great news Damien. Looking forward to the install update and results.
Looking forward to the updates |
Hey Damien, should be fun!
Are you guys also doing a brake upgrade? |
Good question. The owner has opted to try the stock brakes out for a bit at first and then make his decision based off how well they cope. Depending on his driving style, they might be sufficient, but I'm sure he will at the very least end up opting for a pad upgrade - but lets see. |
Brave man.
Is it a Std or a High spec? Lot more pad options for high. |
The stock brakes, even on the HI spec are rubbish...Just the other day, I made them burn with just a spirited drive home.
Im pretty sure with just a pad upgrade they will be much better....Now dont get me started on the stock tires..... |
I fitted on the EBC Yellow Stuff brake pads this weekend. Got it at a great price for R1550 from Star brakes in Edenvale. Have to take it easy for 500km - 1000kms before I really step on them. Will provide feedback once runned in
I agree with you guys, I think he will be replacing at the very least, pads once he has had some seat time.
Will provide impressions once its properly tuned, first start should happen this evening :cheers: @RueFT86, thanks for that. I have also had good experience with EBC but will also be looking at PowerBrake for options. |
The most important issue isn't pads - it's brake fluid.
When pads overheat, they fade and you'll feel them going off progressively. You get a 2nd chance... Even when a pad disintegrates, you get a 2nd chance. When brake fluid overheats, it boils, and your brakes catastrophically fail. No 2nd chances... I repeat what I've said before - don't venture onto a racetrack with stock fluid - the brakes WILL FAIL after 5-6 laps when the fluid boils. A good fluid which is affordable is Motul 660, available in most motorbike shops at about 40% of the price of Endless RF650. Trust me when I say this - I've done 16 track days in my 86 and I learnt the hard way. I also thought I'd just put my toe in the water and see what happens. Fortunately my brakes failed and I went off where there was nothing to hit. |
| All times are GMT -4. The time now is 10:19 AM. |
User Alert System provided by
